DIY Electric Car Forums > Blogs
Old
DIY Electric Car Highlights and Progress
Posted 02-03-2009 at 02:42 PM by mattW
The DIY website has been going under some pretty impressive changes and has included some pretty interesting threads over the past few months, but with over 3000 members and an average of 400 new threads a week there is a lot of content to go over. So I thought it would be helpful to pick out some of the highlights of what I have found to be the most interesting threads and developments of DIYelectriccar over the past few weeks:
The DIY Garage; Robert has done an amazing job in designing,...
Click image for larger version
ID:	34   Click image for larger version
ID:	35   Click image for larger version
mattW's Avatar
Posted in Editorials
Views 1765 Comments 2 mattW is offline Edit Tags
Old
Step 1: How to plan a DIY Electric Motorcycle
Posted 02-03-2009 at 02:34 PM by mattW
Last week I said that this blog would be part journal, part guide to the conversion process but I've decided to separate those two categories by having a build thread for the bike with pretty pictures and having this blog as a sort of step by step guide. I'll still give you updates here but primarily the build thread will be about how I'm doing it and the blog will be about how you can do it. Step one in that process is making your plans, what do you need to know in advance before you start in order...
mattW's Avatar
Views 3062 Comments 1 mattW is offline Edit Tags
Old
Elixxer - An Electric Motorcycle is Born
Posted 02-03-2009 at 02:32 PM by mattW
I have been researching Electric Cars since September last year, in that time period I have gone through many plans and thrashed out many budgets as I worked out how a student could make a satisfactory EV. I have planned an RX7, CRX or Civic and pick-up conversion, even to the point of being outbid on eBay for a donor. I started my own mini EV project as documented on this Blog, but since it was going to be just a toy, that I couldn’t fit in and didn’t feel comfortable giving away without testing,...
ID:	27   Click image for larger version
mattW's Avatar
Views 1810 Comments 8 mattW is offline Edit Tags
Old
Lithium vs Lead; the Great Cost Debate.
Posted 02-03-2009 at 02:21 PM by mattW
I've decided to try and work out the cost comparisons for a Lithium pack vs a Lead pack for a set range and a set number of years. Is Lead Acid actually cheaper or does is just seem that way up front? This article aims to find that out. The method is to get 10kWh of usable energy, I’ll try to get that with Lead and with Lithium and see what we find is cheaper in the long run. Assuming an efficiency of 250Wh per mile (a compact car) we should get a range of 40 miles (65km) with either pack. I’ll...
mattW's Avatar
Views 4681 Comments 154 mattW is offline Edit Tags
Old
Oil - it’s not you it’s me.
Posted 02-03-2009 at 02:19 PM by mattW
Tags oil, tric cars
Ah Oil, we’ve had plenty of good times together haven’t we? Remember me learning to drive… buying my first car… our first road trip together. We’ve made some pretty good memories… you and I. But if I’m honest I think we should start seeing other fuels. The last thing I want to do is hurt you but I think we are just drifting apart, heading in separate directions. You are having such a fantastic career, you’ve really found your niche and that more expensive demographic really suits you. I know your...
mattW's Avatar
Views 854 Comments 11 mattW is offline Edit Tags
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
