One can turn 2001-2003 Prius as Electric Car very easily and cheaply ..All one has do is to remove the EFI fuse once ign. is no and you get "READY" indication. But now it well only go about 1.7 or less unit the HV battery down to far.So one well need to add Power to the HV Battery. It can be done by using, a 2nd gen Prius Boost converter. One needed about min of 160 volt. of battery power , the boost converter well increase the to about to about 306 V that should keep the HV battery (OEM)...
