Re: [EVDL] EVLN: 49% of houses & 14% of Apt's can chargeaplugin-vehicle @home
Well, that sounds like an ESVE, just not from a well known manufacturer
To be fair, I think one should include the cost of all these parts. I
wonder how much it costs all together: NEMA jack and plug, J-1772,
electronics, and any cable, etc. Hopefully way cheaper than the cheapest
commercially available ESVE.
Peri
-----Original Message-----
From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On Behalf
Of Cor van de Water
Sent: 05 July, 2012 1:25 PM
Subject: Re: [EVDL] EVLN: 49% of houses & 14% of Apt's can
Probably with one of the portable EVSE, in other words:
standard plug on one side (like a NEMA 14-50 in this case)
and a J-1772 plug on the other side with in between a
little box that controls a relay and the pilot signal and
has GFCI. Can be fully J-1772 compliant without much cost,
in fact cheaper than having a permanent installed EVSE.
Cor van de Water
Chief Scientist
Email: xxx@xxx.xxx Private: http://www.cvandewater.com
Skype: cor_van_de_water XoIP: +31877841130
Tel: +1 408 383 7626 Tel: +91 (040)23117400 x203
Behalf Of Peri Hartman
Sent: Wednesday, July 04, 2012 5:49 PM
To: 'Electric Vehicle Discussion List'
Subject: Re: [EVDL] EVLN: 49% of houses & 14% of Apt's can charge
Did you also install a J1772? Or, how are you charging your leaf?
Behalf Of Dave Davidson
Sent: 04 July, 2012 9:26 AM
Subject: Re: [EVDL] EVLN: 49% of houses & 14% of Apt's can charge a
Houses in my neighborhood don't even have garages. Just a driveway
beside the house. Yet when I had some remodeling done several years ago,
I had an "RV port" installed on the wall beside the driveway, which
includes a 240V/50A receptacle. Cost was minimal. My Leaf sits outside,
I plug my Level 2 into the receptacle, and charge away. It would be
quite easy to mount a Level 2 unit on the wall permanently.
Dave
Peri
Of Cor van de Water
Cor van de Water
Chief Scientist
Dave
