12v deep cycle AGM's - DIY Electric Car Forums
Old 02-19-2008, 11:08 PM
ifelder ifelder is offline
ifelder is on a distinguished road
Default 12v deep cycle AGM's
I am starting to tackle my battery problem, I'm going to run a 72 volt system and have two choices.
12 deep cycle 6Volt batteries, or 6 12V deep cycle batteries.
If i go with the 6 12V batteries, which will reduce my range i thought i might ought to at least get batteries that will last me the longest amount of time with the least amount of effort. Optima Yellow top batteries seem to be what i need as i wont have to vent or fill them and can mount them about anywhere... Then i saw their price, which was still steep for the connivence.
I hopped onto craigslist and found this listing
http://dallas.craigslist.org/pts/569582302.html
for 12v sealed AGM batteries, I'm not sure if they are deep cycle could anyone tell me if these batteries are suitable for an EV?
Also, could someone ballpark the range i would be getting with about a 2,000lbs car with a 72V controller and the 12volt pack or the 6volt pack?
Advertisement
Old 02-20-2008, 08:34 AM
elevatorguy's Avatar
elevatorguy elevatorguy is offline
elevatorguy is on a distinguished road
Default Re: 12v deep cycle AGM's
I personally would go with the 6 volt if you can take the weight difference and have the room. The down side is about 300 pounds more and 500 dollars.
The up side is double the capacity, more range. I have used t-105 trojan for comparison and this is without shipping, you could save more if you find a golf car supplier close and save shipping. I have heard you will get less life out of sealed batteries, as in 3 vs 5 for wet cells.
You might want to check the wiki here, and www.evalbum.com for ideas on range from other conversions.
hope this helps,
Jerry
http://www.austinev.org/evalbum/preview.php?vid=1174
Old 02-20-2008, 12:30 PM
are there any problems associated with mixing battery voltages? such as 6 6V and 3 12V wired together in series? i assume i would have problems maintaining them, and one section would die out before the other...
Ian
Old 02-20-2008, 12:53 PM
I think that if you mixed them, the current would have to be the same for each string or bad things would happen, most likely short life on battery pack.
Your range would likely be on par with the lower AH string as they would discharge and voltage would drop.
I have not heard of this being done, perhaps someone else has.
my two cents.
Jerry
Old 02-21-2008, 02:29 AM
MitchJi MitchJi is offline
MitchJi is an unknown quantity at this point
Hi,
You have more than two choices for a 72 Volt System. For example you could use 6 pairs of 12V batteries.
Mitch
Old 02-21-2008, 04:40 PM
Wirecutter Wirecutter is offline
Wirecutter is on a distinguished road
Here's how I did it - YMMV:
http://www.evalbum.com/1274
I really need to do a proper range test. Based on how long I can drive at speed, I'd guess I have 30+ miles of range.
-Mark
Support DIY Electric Car
Sponsors
