Old 03-15-2008, 06:16 PM
Dennis Dennis is offline
Dennis is an unknown quantity at this point
Default Re: 144V controllers
You'd require a Permanent Magnet motor to use the regen feature on that controller.
Most EV motors are Series Wound Motors, which to my understanding there is no way to have actual "regenerative" breaking from these motors, only forced motor breaking which takes up energy.
You forgot to mention shunt wound motors which can also do regen. Some people perfer to call them seperatly excited motors since the controller controls the shunt field and armature independently.
Old 03-26-2008, 11:15 PM
chrisst907 chrisst907 is offline
chrisst907 is on a distinguished road
A 144 v controller is not that much, They run between $1250 and $ 1615 depending on the AMPS you have to remember when looking at that controller that is is being MARKED way up. I have a price list of the true prices if you are intrested
Old 03-27-2008, 01:21 AM
Dan Frederiksen Dan Frederiksen is offline
Banned
Dan Frederiksen has a little shameless behaviour in the past
I would very much like to see those prices
Old 03-27-2008, 08:13 AM
Hi, since I do not know what you are interested in specifically, I am posting prices for the automotive controllers and not the smaller "golf cart" ones.
Let me know if you have anymore questions
48-72 volt 550amp $980
48-72 volt 750amp $ 1,115
48-72 volt 1000amp $ 1,280
72- 120 volt 550amp $ 1,210
72- 120 volt 750amp $1,345
72-120 volt 1000amp $1,480
120-144 volt 550amp $ 1,250
120-144 volt 750 amp $ 1,345
120-144 volt 1000amp $1,615
120-156 volt 550amp $ 1,345
120-156volt 750amp $ 1,590
120- 156 volt 1000amp $1,825
Old 05-07-2008, 02:51 PM
frodus's Avatar
frodus frodus is offline
frodus will become famous soon enough
except the kelly controllers do not currently support shunt wound motors...
Old 05-08-2008, 07:32 AM
MrCrabs MrCrabs is offline
MrCrabs is on a distinguished road
Their site says they do.
http://www.kellycontroller.com/mot/B...ontroller.html
However they only go to 72 volts.... so only good for a small car or motorcycle
Old 05-08-2008, 09:33 AM
frodus's Avatar
hot damn, they keep adding controllers don't they....
my appologies! But you're right, they're still limited to 72V.
Old 05-12-2008, 10:55 AM
headrush headrush is offline
headrush is on a distinguished road
They do have controllers with higher Volts:
http://www.kellycontroller.com/mot/H...ontroller.html
but no where near the price of the other ones you were looking at.
Old 05-12-2008, 11:34 AM
frodus's Avatar
you're comparing apples and oranges..... shunt wound controllers and series/PM high voltage controllers.
Old 05-12-2008, 05:11 PM
I did not see that. Man you learn more everyday. And as I have no idea about the difference, would you mind explaining?
Tags
144v, controllers, curtis, kelly, zilla
