Old 11-01-2011, 10:55 AM
spdas's Avatar
spdas spdas is offline
spdas is an unknown quantity at this point
Default Re: 1972 Mini Cooper E.
Aloha, It is a strange model then. As the 998 is the later Cooper engine, 997 was first. But I think the Cooper S came with 998, 1071 and 1275 engines. I never heard of a Cooper or Cooper S with drum brakes in front. And it has the right hand Cooper S gas tank (making twin tanks). So it is a real oddity to me. Someone in the UK would have to figure it out then. But it will make a nice EV!
Francis
Old 11-01-2011, 12:12 PM
Jaesin Jaesin is offline
Jaesin is on a distinguished road
Francis
The twin tanks do look original. I tried looking up the VIN (MXA251 717-850N) one day but it wasn't conclusive. I think it might be Australian made (Near Perth). Made by Morris BMC. This is kind of a hunch. When I got the car, it had what looked like old New Zealand plates and the VIN doesn't look like a UK VIN. It was original (besides being repainted) with no rust at all. They did make a Cooper S model but I read AU cars had some different features. Maybe they ran drum brakes in AU.
I don't really know.
-J
Old 11-02-2011, 12:25 AM
Duncan Duncan is offline
Duncan is on a distinguished road
Hi Guys
Cooper S
started with a 1071cc large bore engine - there were 970cc and 1275cc variants - the last 1275cc S was made in 1971
It had hydrolastic suspension
The Cooper started with a 997cc and a pair of dinky disc brakes that were less effective than the drums
went to a 998cc with discs that were as good as the drums
The S came out with a pair of slightly larger discs
the 1275GT has a different block, crank, rods and bigger discs (need 12 inch wheels)
I think you have a mini 1000 with an extra tank! - is it hydrolastic?
If so remove the hydrolastic bits and fit the rubber suspension (preferably from a 1977 or later)
I don't think you will be able to sell it as a Cooper S
You seem to have a rod change gearbox - that came out in 1973 and has a completely different exhaust tunnel and much better driveshafts - much better my old 1430 used to bend the old rubber hardysplicers - I got used to changing them fast, the inboard CV joints are much better
Old 11-02-2011, 02:00 AM
Wow Duncan, Thanks for all the info.
Does that cover Aussie cars as well?
I read that they started installing roll up windows in Australia before they did on UK cars. Being that the environment is different, I imagine there are other inconsistencies as well.
I don't have hydrolastic suspension.
Whatever my car is, It's not a UK Cooper S so even if it was an Aussie Cooper S, It's still not worth what an original UK Cooper S is worth. By time I'm done with it, it will be very something completely different anyway. A custom Cooper E with adjustable suspension and all wheel disc brakes.
Originally Posted by Duncan View Post
Hi Guys
Man.. 1430cc sounds like a monster, hahaha.
The gearbox is a spare. I have the rest of the engine if anyone is interested in it (998cc "99H791P"). I need to get rid of it.
I will probably go by the local Mini supply shop to pick up the suspension parts on Thursday. Is there anything I will need to match the gearbox to my '72? I guess I will have to check the gearbox in the car before I go. What should I look for to tell which gearbox is in the car.
The Coil Conversion:
http://www.7ent.com/products/coil-sp...ts-for017.html
- Jaesin
Old 11-02-2011, 03:04 AM
Hi Jaesin
I would be very wary of that coil spring set-up
The mini doughnuts are very progressive - they have to be because of the limited travel
the advert says
Road handling will be similar to rubber cone suspension, but with a big improvement in ride quality.
- simply not possible with a steel spring
lot of money for a retrograde step
Why do you want discs on the back? - the drums have to be limited by the proportioning valve
Aussie minis
They did some strange things but not I think cooper S's
Gearboxes
The earliest gearbox had a meter long gearshift lever coming straight from the gearbox - horrible
The cooper gearbox had a nice aluminium extension going to a shorter gearlever,
(the cooper box has the extension bolted to the gearbox - the old 1100 had a similar unit bolted to the gearbox through a rubber mount)
in about 1972-73 the rod change gearbox came out this has two rods going back to a housing bolted into the exhaust tunnel - this gearbox also came with the inner CV joints
My 1430 had a cooper box with the diff bits changed to have the inner CV joints,(after I had broken a lot of the older joints)
One of the problems with the old minis was the engine/gearbox unit used to try and tear itself loose, - mainly torque reaction
The advantage of the old cooper box was the long aluminium extension gave a nice long lever to stop the engine from rotating
Look at your exhaust tunnel - the pre-rod change shells had a bulge near your left foot, in the very first minis there was a floor mounted switch there
the later exhaust tunnels are much squarer without the bulge
I think you can use the earlier shells for a rod change but you may need to make a mounting bracket and dress the exhaust tunnel out a bit
My 1430 went for about 40,000 miles then the 1430 A series was a bit tired so I replaced it with - a 2000cc Lancia twincam + holbay cams and a pair of webers
Fun days!
Old 11-02-2011, 07:04 AM
MalcolmB's Avatar
MalcolmB MalcolmB is offline
MalcolmB is on a distinguished road
I agree with Duncan about the coil setup and brakes. I've looked at doing this at the front and rear (with a beam subframe). The consensus on the UK mini forum is that the standard rubber doughnuts and brake setup are very good and you can waste a lot of time and money trying to improve on them. The most cost-effective way to improve handling is to fit new doughnuts and dampers, as the rubber doughnuts last about seven years before stiffening up. Since you'll be changing the weight distribution it's also worth fitting hi-los – replacement suspension cones that let you adjust the ride height front and back.
As for brakes, the front drums are actually pretty good if well maintained. The 8.4" discs are a significant improvement. It's not worth doing much at the back, as the performance of the existing drums if well maintained is more than you can use – it's limited by the proportioning valve, as Duncan said.
I'm fairly sure you'll also need the later drive shafts to mate with the pot (CV) joints on your replacement box.
Mini conversion:
http://www.diyelectriccar.com/forums...ad.php?t=52461
Old 11-03-2011, 12:05 AM
Hi Jaesin
There is one suspension mod I would recommend
Longer front lower suspension arm,
If you can get a blank you drill the tapered hole for the bottom ball joint 6mm further out otherwise you cut two arms and weld them together - they are H section so it is easy to fill the H with two reinforcing bars and weld the whole mess together
Another tip - don't try and use a sexy small steering wheel
a powerful mini has torque steer - it can rip a small wheel out of your hands
We used to laugh at the guys with the small wheels as it showed they were show not go
otherwise there is not a whole lot worth doing - unless you replace the whole suspension
The adjustable Hi-Lo's are useful but you can do the whole thing with washers and a file
(much easier with the Hi-los)
Old 11-04-2011, 05:05 AM
First of all, I just want to say thanks for helping me keep my focus on this project.
I was originally thinking about adjustablilty. I've had the car for about 6 years now and I think the cones are a bit harsh for daily driving so I kinda wanted to try something different. I think these are even cheaper than the doughnuts: http://www.gbcarparts.com/proddetail...=SR-SpringsRED so I still might try them. I've read some post from a few guys that have put them on: http://www.miniaddicts.co.uk/forum/showthread.php?t=954, http://www.theminiforum.co.uk/forums...howtopic=65132
This is what I have. A long rectangular aluminum tunnel attached to the gearbox. Complete with floor hump by the driver's seat (RHD). I am not sure if the tunnel will attach to the rod change gearbox. It doesn't look like it.
Inner CV Joint:
http://www.gbcarparts.com/proddetail...ntInner&cat=19
Anyone know what's invovled with converting to inner CV joints?
I mainly wanted the rear discs for cosmetic and weight saving but I am going to hold off on all not essential upgrades for now. It's a good point to think about the cost of all this stuff. I was getting a little too excited about wasting money. hahaha.
The last couple of years have been hard on "Champ". I am going to need to do a fair bit of body panel work. I should definitely take care of that and get some new paint before wasting money on stuff I don't need.
- Jaesin
Old 11-04-2011, 07:28 PM
Hi Jaesin
Replacement springs
The problem is the mini has a short wheel travel and small wheels -
the springs have to stop the wheel movement when you hit a bump before you hit the bump stops
(this is why soft springs sometimes feel very hard - you are hitting the stops)
A simple steel spring has a constant rate (lbs/inch) so if it is going to stop the movement in a short distance it must have a very high rate,
The rubber doughnuts have a rising rate - so they are softer in normal use but can still absorb that big bump
Steel springs don't work - the only reason these people are reporting otherwise is because they have spent the money or their old system was knackerred and the have fixed it at the same time
Malcom suggested replacing them with new ones - the early ones were stiffer, in 1977 the factory went to softer units
if you have 1972 units they are both stiff and old
If you have some spare ones some people used to soften them by drilling holes in the rubber
try about 4 off 1/2 inch holes - the holes will go a funny shape when you take the drill out - this is normal
If you have spares you can do a suck it and see
Later drive shafts on an older gearbox
I did this on my 1430
You have all of the bits you will need on the other gearbox, take the diff side covers off - I think you will need the diff output shafts
If you get a later disc brake setup you will need the CV's and drive shafts as well
Its all pretty clear when you get the bits together
Old 11-04-2011, 10:51 PM
Thanks Duncan!
Sracer advertises that the springs are progressive. http://www.sracer.com/catalog/products/srp001.htm. Maybe not as progressive as the cones. Who knows, it's hard to get specs for these things. I had new doughnuts on it when I got the car but maybe they were not late model replacements. It could be that the seller wasn't perfectly honest.
I do appreciate you keeping me informed.
So I guess I will need to rebuild the diff to use the older output shafts because I don't really want to buy new CV joints and axles at the moment.
Maybe it's possible to get standard axles but the ones I have sourced so far are beefed up $500 units. Ouch!
-Jaesin
Tags
champ, classic mini, mini cooper, san francisco
