Re: 60 HP ...830lbs AC Motor...will it work???
ADEYO
Ok going to try and keep this basic. You really need to figure out what voltage you are going to run (motor and controller) The higher the voltage the more batteries you will need, and lith. batts. are not cheap... So with that in mind, that is why i choose to go with the Curtis 1238 controller.. I am only gone to run 30-32 200amp hour lith batts.. You allso need to look at motors, not just the hp and amp, but the continuous rating. Like Kevins motor is 50hp CONTINUOUS unlike the ac50 says 67-70 hp, sounds good, but it is only 20hp continuous.. Big difference.. I was originaly planning on using the ac50, but i live in Tucson AZ, it is 108 today, I feel that motor would not push my extended, loaded 1999 sonoma pickup. I am buildin a little bigger motor and building a water jacket for the housing. So since i am using the 1238 curtis controller with a output 70 rms volts, I need to rewind the motor for 70 volts..I hope this helps a bit more.
Just installed the trans and motor in the truck today. Need to build the water housing and rewind stator..
Ivan's Garage 1999 Electric Sonoma Pickup
http://ivanbennett.com/forum
This is just a test! Hand wound motors.
