hi everybody! i'm very new to the forum, and i'm reading a lot without posting, i'm try to understand the world of electric veichles that for me it's always not easy to get... specially the tecnical part.
briefly there is something maybe that i'm missing... and to talk about that i will post a video that i found on internet.
http://www.youtube.com/watch?v=tF4IqRsJPj8
my goal is to convert my motorcycle to electric and i tell you why, i asked you many times ago about convert a small light car, and i realize that my thought was quite unrealistic.. mainly cause the important actual limitation of the batteries power to weight ratio. anyway... i'm a motorcyclistis since year and i need a veichles just for me for what i'm doing (go to work )... so i tought to the motorcycle because is lighter then the motorcycle so "in theory" i need less power to run... and for this reason a potential higher miles range.
you will say "yes" but you are less space to put the batteries... and that's what i want to talk...
first thing i found a engine that is really small respect engine used for car, and i don't understand if can be enough to move and run the motorcycle at decent speed (i suppose that the video use the same motor that i'm mention it.. so it supposed to work fine) this time i'm not looking for extreme speed... but just let say just enough power to some SAFE overtaken and the rest is use less throttle possible and respect "most" of the speed limit.
i recently found this other video... but it seems everything expensive
http://www.youtube.com/watch?NR=1&v=ULIDRrYrDIk starting from a strange engine that i don't recognize and i don't understand why even if it's pumped at 96- volt and have two engine... the battery pack it's really small.... so i really thinking that with just one small engine pumped at lower voltage with more battery i really can get higher milege... (of course no performance)
for controllers and other parts it seems that my motorcycle have quite a lot of space in the tail... and for the battery i can easily store the same or maybe a little bit more battery that they put in the video..
using the same and expensive battery like the thundersky, how many batteries i need to buy? yes she said in the video 28 battery, but what does it mean in term of amps, volts and all the caractheristic that i found when i want to buy some batteries? (you know what i mean)
and how much voltage for the engine? i understood that if you have a high voltage setting for the engine i will have more power and less milege.. if i put less voltage i have less power and more milege... is it right?
thank you for any help..
