Azure DMOC 445 vehicle ready light output? - DIY Electric Car Forums
Old 01-16-2014, 04:24 PM
Axon Axon is offline
Axon is on a distinguished road
Default Azure DMOC 445 vehicle ready light output?
Hi,
I'm currently working on an EV conversion that uses an Azure DMOC 445 motor controller. I'm trying to wire an LED to the controller to work as a vehicle ready light to indicate when the motor controller is active and ready and was wondering if the there is a designated output for a vehicle ready light or an output that could be used to run an LED.
Old 01-16-2014, 10:31 PM
PThompson509 PThompson509 is offline
PThompson509 is on a distinguished road
Default Re: Azure DMOC 445 vehicle ready light output?
I just looked through the manual, and did not find anything that looks like it would work. I don't recall if I had anything that would do that when I had one either. Sadly, I lost my diagrams in a hard-disk crash, so I can't refer to my older docs.
Do you have a copy of the manual?
Old 01-18-2014, 04:54 PM
I do have a copy of the manual.
01-05-07 DMOC445 User Manual_v5.pdf
Unfortunately it's bit ambiguous about what some of the ports do. I'm also not too familiar with the system so I haven't really been able to get a lot out of the manual.
Old 01-18-2014, 09:02 PM
Well, since you have the manual, you have as much as I do and more - since I no longer have the DMOC.
Best of luck - hope someone else can answer the question.
Old 02-08-2014, 12:49 AM
joeboxbaytown joeboxbaytown is offline
joeboxbaytown is on a distinguished road
maybe these can help
Old 03-18-2014, 06:53 PM
rclugnut rclugnut is offline
rclugnut is on a distinguished road
I'm guessing this for an SAE Hybrid or electrical vehicle challenge? I know CCshell will tell you when the contactor closes. I'm not sure if you can program the controller to output anything when that happens potentially you could do something really funky with the drive enable switch/ fwd/n/rev switch, and when the controller accepts those commands. Beyond that, you could get really sketchy and tap into the controllers contactor, and do something with that. But that could very quickly get non rules compliant. Best bet would be doing something from the BMS.
