Old 09-21-2009, 02:35 AM
chansen chansen is offline
chansen is on a distinguished road
Default Best range - high RPMs in 2nd or low in 3rd gear?
Just finished my conversion and I was wondering, should I try to keep the RPMs low to achieve the best range? I suspect low RPMs in 3rd gear might draw higher current and loss of range vs just letting the warp9 motor spin faster in 2nd.
Old 09-21-2009, 02:43 AM
Amberwolf's Avatar
Default Re: Best range - high RPMs in 2nd or low in 3rd gear?
Very basically:
Faster the motor spins, the higher the BEMF, so the less current it draws; letting the drivetrain do the speed-to-torque conversion to get similar power output to the wheels for less battery current used.
It could be explained a lot better by many others here, but as I understand, that's the gist of it. It certainly works on my CrazyBike2 that way.
Watch me build an electric bike from assorted junk!
Alternative Energy Sources for the Home from Recycled Junk
ReThink, RePurpose, ReUse.™
A subsidiary of Cybernetic Necromancers, Discorporated:
"We Bring Dead Things To Life"
Old 09-21-2009, 06:05 AM
kek_63's Avatar
kek_63 kek_63 is offline
kek_63 is on a distinguished road
Search the Wiki and the forum - this comes up often.
Simplest answer - Low rpm = high amperage = low efficiency+heat
Keith
Better than a kick in the ass with a frozen muk-luk!
Old 09-25-2009, 08:38 AM
I think that's a good way to look at it. Power is the product of torque and angular velocity. Running in a lower gear means the motor has higher shaft angular velocity for a given wheel velocity. The motor power is then the product of a lower torque and higher shaft velocity and is equal to the power at the wheels which is the product of a lower angular velocity and higher torque due to the mechanical advantage of the overall gear ratio of the vehicle. Motor torque is pretty much proportional to current, so less current is required to produce the lower motor torque. So as you say, for better efficiency you want to use the mechanical advantage of the gearing to transform a lower motor torque to a higher torque at the wheels, so less current to the motor is required.
Tom
Old 09-25-2009, 11:01 AM
I'm doing some "field" tests on this by measuring the DOD on multiple daily commutes (20 miles) in which I either use 2nd or 3rd gear for the whole trip. It will take me a month or two to collect enough data that it becomes statistically significant. I will post the results when I am done.
Thanks for the tips.
Old 09-26-2009, 11:11 AM
awesome...thanks chansen!
Old 09-27-2009, 08:36 AM
Astronomer Astronomer is offline
Astronomer is on a distinguished road
Can't someone with a current meter on the dash just run a short course two times in two different gears and simply observe which requires more amps?
-Brian
Conversions: 0
Electrons Bullied into Submission for Future Conversions: 3.6 * 10^19
Old 09-28-2009, 05:17 PM
roflwaffle roflwaffle is offline
roflwaffle is on a distinguished road
What are the 2nd/3rd gear ratios, axle ratio, and tire size? You should be able figure out what's best for efficiency from the Warp 9 map. Generally speaking, 2000-4000rpm is where you want to be.
Old 09-30-2009, 02:58 PM
I think his setup is for 120V. The graph you reference is for 72V.
Does the voltage make a difference what rpm range is most efficienct?
Old 10-06-2009, 01:28 AM
I don't think it changes it much, but I'm a layperson so take that with a grain of salt barring verification.
