Old 10-02-2009, 07:54 AM
piotrsko's Avatar
piotrsko piotrsko is offline
Default Re: Best range - high RPMs in 2nd or low in 3rd gear?
Originally Posted by E4mula View Post
I've run some tests like that. Constant speed over the same course through different gears. Average power consumption over the course increased when shifting into higher gears.
new question: which gear made you faster through the course and can you give some data as to watts per ET?
Old 10-05-2009, 04:01 PM
chansen chansen is offline
chansen is on a distinguished road
I calcualted that for my transmission ratio, final drive and tire size the following RPMs for the Warp9 motor:
http://www.kabamus.com/garage/gears.html
in 2nd and at 45 mph => 5000RPM
in 3rd and at 45 mph => 3500RPM
So it seems that 3rd is the right gear for everyday driving, given the Warp9 info from a previous poster. My problem is that in 3rd, the acceleration from stop is slower than other vehicles on the road. I live in hilly area so I often stop on an incline.
Old 10-06-2009, 01:28 AM
roflwaffle roflwaffle is offline
roflwaffle is on a distinguished road
Originally Posted by Bowser330 View Post
I think his setup is for 120V. The graph you reference is for 72V.
Does the voltage make a difference what rpm range is most efficienct?
I don't think it changes it much, but I'm a layperson so take that with a grain of salt barring verification.
Old 10-08-2009, 01:34 AM
frk2 frk2 is offline
frk2 is on a distinguished road
Ive done tests in my car from my home to office trip (8km). I would drive in third from stop on one trip and then 2nd-3rd (shifting). The 1rst option (3rd all the way) consumes marginally more energy (maybe 10% more), gives me far better acceleration and is all round pleasant. 2nd to 3rd actually results in bad acceleration for me since my 2nd gear is REALLY high (3.1:1) with a final 3.6 ratio so 10:1 gear to the wheels.
I simply drive in third.
Old 10-08-2009, 09:38 AM
So to clarify, the 2 to 3 shift option results in bad acceleration because the shift required takes more time than just leaving it in 3rd and flooring it...even though the lower gear (higher multiplication) gives you better INITIAL acceleration, the requirement of the shift bogs down the overall acceleration...do i understand that right?
Old 10-08-2009, 11:29 AM
Sorry for being vague - yes the shift bogs me down. Also although my VERY initial acceleration in 2nd is good - the power quickly tapers off as the motor enters high revs. This means that I have to quickly shift to third (this is due to my car's weird gearing). Overall its better if im driving in the lower (3rd) gear. Keep in mind that my 3rd may very well be your second - max speed in second = 35kmph and in 3rd = 65kmph.
