Old 07-26-2012, 02:18 AM
circuit's Avatar
circuit circuit is offline
circuit is on a distinguished road
Default BLDC controllers suitable for very low inductance motors
There are many low inductance motors around these days. By low I mean 5μH and lower. These are coreless or compact outrunners.
The problem is that the inductance is so low, that it is unable to integrate the PWM and current ripple blows the controller or overheats a motor. Or significantly lowers motor's maximum useful current at least.
So, since there ARE such motors, what controllers do they run with? Anyone know of such controller available to buy or any kind of info at least?
Visit my blog and company's website
Personal projects: E-bike v2 | e-scooter: part 1, part 2
Old 07-26-2012, 06:32 AM
Tesseract's Avatar
Default Re: BLDC controllers suitable for very low inductance motors
The rule of thumb here is the lower the winding inductance the higher the switching frequency needed to maintain control over the winding current, all else being equal.
However, both "iron" and winding losses go up with frequency, and in the specific case of the iron losses they typically increase at the 1.6 power of frequency. Also, switching losses in the inverter go up with frequency, so you will have reduced efficiency there, too.
Whether or not what you want is practical will depend on the max battery voltage and phase current desired. A high switching frequency generally means using MOSFETs as the active devices in the inverter, but above 250V and 300A per phase they give way to IGBTs, which typically max out at about 20kHz in hard-switched applications (as compared to resonant or soft-switched modes of operation).
Finally, the need to meet EMI emissions regulations - especially in the EU - also limits the PWM frequency. Most such regulations begin measuring emissions at 150kHz and since PWM waveforms contain significant amounts of odd harmonics (proportional to 1/n, where n = harmonic number) this is often the biggest limiting factor on the switching frequency, regardless of the capabilities of the hardware.
Old 07-26-2012, 07:52 AM
circuit's Avatar
Well, thanks for the theory. Nothing new there.
But my question is still open. I want to find any production controller and how it (if any exist) solves the problem:
1. Used only with coreless motor and feed enormous frequency PWM
2. Work in enormous frequency and filter it out with onboard LC filters
3. Any other, maybe smarter way to achieve the goal.
Old 07-26-2012, 08:30 AM
Arlo Arlo is offline
Arlo is on a distinguished road
Circuit. Here is what I can find off the top of my head.
These guys had a claim they could get some really tough to drive 3phase AC permanent magnet motors ripping. http://www.rinehartmotion.com/products.html
And the Tritium wave sculpture but the pages can not be found???
There is one or 2 more companies I have seen talked about over on ES but I have to find them.
There is a reason I have learn't how to build and design 3 phase motor controllers and I have had 2 colossus paperweights for over 2 years!
If I could get someone to do my 60+ hours of work I have a week right now my motor controller would be done in no time!
Worlds fastest electric bmx? http://www.youtube.com/watch?v=HSh8uGcFpJs
Yamaha E-YSR with 15kw DIY BLDC controller!
http://www.youtube.com/watch?v=91pGd...6Y37xYFFPRdPhw
Old 07-26-2012, 09:03 AM
Tesseract's Avatar
Yeah, well, you asking the question in the first place kind of implied you didn't realize this. Also, you didn't specify an operating voltage and desired power level so how could anyone suggest a specific inverter?
Old 07-26-2012, 09:17 AM
circuit's Avatar
Same here. Started the project back in 2009.
Will drop them an email.
Sorry I did not make it clear from the start. To me this problem looks so huge, that I was asking for a link to ANY KIND of controller that is able to turn low inductance motors without pushing enormous amps at no load.
Old 07-26-2012, 11:31 AM
I ran colossus with a 18fet controller with no load at ~6500-7000 rpm (100v) and it was sensored running ~7 amps so thats not huge. Are you sure you dont have another problem???
Old 07-26-2012, 11:37 AM
circuit's Avatar
Are you still running it? Somehow I did not see anyone actually running it.
I ran similar motors with 18fet LYEN "just fine". And current draw was "not that high". Only few amps at battery, but a hundred amps on phase...
7 amps at 100V is 700W of loss, while doing nothing. Colossus is a bit too small to get rid of 700W heat by its own.
And what is the inductivity of colosssus? From its dimensions I'd guess its around 15-20uH.
Old 07-26-2012, 12:05 PM
Collossus is 8uh its liquid cooled and been rated at 20-30 hp continous. Splinter has a working bike with colossus in it using a kelly. No running hi power but it does drive like a normal bike. I have posted a few videos of colossus running on the bench and using external inductors to ride it around. But now im using lebowskis chip for my controller all i need is a free afternoon to be running it!
Old 07-26-2012, 01:05 PM
frodus's Avatar
frodus frodus is offline
That's not 700W of loss, that's 700W going to the controller. Just because it's not loaded doesn't mean it's not doing work. The motor is still moving and using energy.
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and parts Sales
Brammo Empulse R #24
