Old 05-21-2008, 06:21 AM
lazzer408's Avatar
lazzer408 lazzer408 is offline
lazzer408 is on a distinguished road
Default Cheapest DC-DC converters. 250w $50, 450w $65, 650w $100 you say?
Ok guys. Check this out. I've been playing with a 250w Thermal Take Power Express power supply. What this thing is, is an add-on power supply for a PC computer that fit in a 5.25" CDrom bay and provides 250w @ 12v regulated to power SLI or Crossfire graphics cards. 2 cards. A slot cover plate mounts in the computer to provide a 120v ac-in jack for a boom-box type power cable. This supply is normally activated when the main PSU turns on but if you don't connect the interface cable to the computer psu's atx connector, then it will always be on. It will power up with DC right to the ac input but it's better if you have the ability to open it and put your pack voltage straight to the main filter cap -after- the line rectifier. I've ran HID headlights as low as 48v input on the cap. Normally this cap sees about 150v. That makes 48-150dc input and 12v out but I would de-rate the output with voltages below 100v.
It's also fan cooled and ISOLATED and I've just discovered they make a 450w and 650 watt version!!!
Typical internet prices:
250w (rated 21a max) ~$50
http://www.thermaltake.com/product/P...0130/w0130.asp
450w (rated 30a max) ~$65
http://www.thermaltake.com/product/P...0157/w0157.asp
650w rated 30a max?) ~100 <---- 30a? It's twice as big as the 250 and 450 and takes up 2 bays.
http://www.thermaltake.com/product/P...0158/w0158.asp
This should make you guys very happy!
http://www.amazon.com/s/ref=nb_ss_gw...+power+express
Old 05-21-2008, 06:39 AM
lazzer408's Avatar
Default Re: Cheapest DC-DC converters. 650w for $100 you say?
I'm tracking down the feedback to try and get 13.8 out of it. This is on the 250w version I have. If anyone would care to donate one of the larger ones I'll figure it out as well and make a nice walkthru for you.
Old 05-21-2008, 09:57 AM
JRK5150 JRK5150 is offline
JRK5150 is on a distinguished road
Wow! Would this actually work as a DC-DC converter? I was planning to run an alternator off the front of my motor, but this would be more efficient and nearly as cheap! If this works, lazzer408, you are the MAN!
Old 05-21-2008, 02:59 PM
KiwiEV's Avatar
KiwiEV KiwiEV is offline
KiwiEV is just really niceKiwiEV is just really niceKiwiEV is just really niceKiwiEV is just really niceKiwiEV is just really nice
This is good news! Well done on your findings mate! This could save us all a bundle!
Old 05-21-2008, 04:06 PM
lazzer408's Avatar
For my motorcycle, I use it at 12v without any problem. Why do autos still retain a 12v battery? There's no engine to start with it. Why not put the dc-dc on a switch and power it up first?
fwiw the HID heallight ballasts are regulating. It will attempt to draw 55w (or 35w depending on the kit) reguardless of the voltage. LED tail/stop/turn bulbs would be as bright at 12 as 13.8. You wouldn't notice much. But I'll continue to track this down for you guys.
Here's the inside of the Thermaltake 250w. Pardon my mess.
Old 05-21-2008, 04:14 PM
Twilly Twilly is offline
Twilly is on a distinguished road
There is a bunch for sale on E-bay right now, Just got mine...
Old 05-21-2008, 04:39 PM
John John is offline
John is on a distinguished road
In a word redundancy. If your DC/DC converter goes belly up you're not going to suddenly go dark. You're lights will still work your vacuum pump will still work and your car will still run.
Old 05-21-2008, 04:43 PM
lazzer408's Avatar
I was thinking that's a good reason to keep the battery. Which is why I'll continue work on the voltage adjustment mods.
What would you guys like the voltage to be? 13.8? 14.2? Let me know that and I'll have this down to "Replace Rx with a x.xk resistor for xx.x volts"
Old 05-21-2008, 06:14 PM
Doesn't an alternator charge at 14.4V?
Old 05-21-2008, 06:22 PM
lazzer408's Avatar
About. But that might not be an ideal float voltage. Depends on the battery I guess.
