Originally Posted by DIT
Got a new motor and now have a controller. Have a major problem with joining the motor shaft to the gearbox.
The motor shaft is 23mm and 28 spline. Can anybody recommend a coupler to join them?
A few pics,
I'd still say it's a little small, It'll move the car but not too well, think of it a the same amount of power as a moped engine.
what is the diameter?
Is it a pump motor?
If you could get hold of whatever it used to drive or something to match the splines then you have something to work from.
Creating a splines coupler from scratch could be very expensive...
Are you using a clutch or not?
Cheers,
