Old 01-07-2012, 12:59 PM
dubelt dubelt is offline
dubelt is on a distinguished road
Default controller for PMS (BLAC) motor
I am searching for controllers for PMS (permanent magnet synchronous) motor
Voltage up to 150V
Amperage up to 500A peak
with encoder feedback or with vector control algorithm
Old 01-07-2012, 01:45 PM
frodus's Avatar
frodus frodus is offline
Default Re: controller for PMS (BLAC) motor
http://www.sevcon.com/ac-controllers/gen-4-size-8.aspx
Sevcon Gen 4 Size 8
  • AC permanent magnet synchronous motor
  • AC induction motor
  • Up to 400V DC supply voltage
  • Up to 100kW peak power output
  • Up to 60kW of continuous power output
  • Integrated logic circuit
  • Includes an additional dedicated safety supervisory processor
  • Will have dual processing and conform to automotive safety standards
  • IP66 Protection
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and parts Sales
Brammo Empulse R #24
Old 01-07-2012, 05:08 PM
How about price ?
or price/preformance
I see that it is based on IGBT modules (400V). When driving 120V motor I could use MOSFET controller - less switching losses.
Old 01-07-2012, 05:47 PM
frodus's Avatar
Not a huge amount.... IGBT's have come a long way. And the problem with your situation, is that between them and Kelly, they're the only ones that make a 120VDC BLDC motor controller that is commercially available. And I won't recommend Kelly.
Not sure about price, you should contact one of their distributors.
sevcon is a great company with good quality and the performance on the controllers I've seen is good. These are their new line.
Travis Gintz
Old 01-08-2012, 04:54 AM
Thanks for reply.
I will write inquiry to Sevcon.
Maybe someone else have found other manufacturer.
I have also found Sigmadrive controllers http://www.dmcde.de
But they limit max. to 120V battery supply
Old 01-25-2012, 07:15 AM
efan efan is offline
efan is on a distinguished road
Originally Posted by dubelt View Post
Thanks for reply.
have you heard back from Sevcon??
and may be you can checkout Zapi's AC-5
they show maximum battery voltage of 152V
http://www.zapiinc.com/products/agriculture/ace5
Old 01-25-2012, 09:08 AM
Sevcon is price killer 8750E / unit
Old 01-25-2012, 04:57 PM
Gary B Gary B is offline
Gary B is on a distinguished road
Voltage up to 150V
I'm just curious. - Where did you find that 75 KW PMS > - Gary B.
Old 01-26-2012, 01:11 AM
It is slightly overvoltaged perm motor. nominal voltage 96V.
Due different battery configuration the nominal voltage will be 115-120V.
Motor is rated at 16kW nominal S1, peak 2.2 x 16kW ~35kW
Old 02-13-2012, 07:25 AM
sokon sokon is offline
sokon is an unknown quantity at this point
before buying a sevcon controller, u might consider my thread on ES
http://endless-sphere.com/forums/vie...p?f=10&t=36146
