Current Sensing Stage
Hello,
I have a problem of performing current sensing, as I'm not sure to what device should I use for it. The problem is that expected current rating should go up to 450A, but it is also expected to be much lower during cruising speeds. Should I go with some kind of IC, op-amps, current sense transformer, or even something else that I'm not aware of.
Any input is greatly appreciated as I'm trying to keep this thing fairly affordable.
Thanx!
