Originally Posted by david85
... but that power cut out is a kick in the teeth.
David, You bought something like 25 or 30 kW nominal? That's what I remember.
Accoording to their website the peak is double. So you have peak power for an unknown time of 50 kW.
Acceleration costs a lot of power. Especially going up a steep drive way. I wouldn't be surprised if you use 40 or more kW so now and then.
Maybe you bump into that unknown period of peak power time. That unknown period of peak power could be surprisingly short.
And there is another thing I find strange about their motors. The air cooled motors are lighter per nominal kW than the water cooled. Normally it's the otherway around. Because with water cooling nominal power can be much higher for much longer.
But they don't seem to take that into account. Or there motors have another problem...?
