Old 03-29-2012, 12:06 AM
Arlo Arlo is offline
Arlo is on a distinguished road
Default Re: David85's saturn SL1 conversion
Finaly found your build I will have to come back and read this later!
Worlds fastest electric bmx? http://www.youtube.com/watch?v=HSh8uGcFpJs
Yamaha E-YSR with 15kw DIY BLDC controller!
http://www.youtube.com/watch?v=91pGd...6Y37xYFFPRdPhw
Old 06-26-2012, 12:28 PM
timpootle timpootle is offline
timpootle is on a distinguished road
Originally Posted by david85 View Post
The heater isn't working yet. I tested it this evening but none of the safe controls are in place to operate it. The contactor relay still has to be wired in, and in such a way that it only sends power to the heater element when the blower fan is running. I also need to get a proper fuse, but I haven't been able to track that down yet.
What sort of contactor are you using for your heater? That's my next job now the Berlingo is charging.
Old 06-26-2012, 05:20 PM
david85's Avatar
david85 david85 is offline
Albright SW60B-7. It came with the heater from CanEV, but its very common and should be available from suppliers in the UK.
http://www.thetoolboxshop.com/sw60b-...80a-7302-p.asp
Keep in mind mine was only drawing about 15 amps at pack voltage (144~160VDC) so the peak voltage rating is relative. Going by the example in the above link, the rating is 3840 watts. Mine was only drawing about 2500 max if I remember right.
All I had to do was build it.. http://www.diyelectriccar.com/forums...ion-26587.html
Forum Rules and terms of service:
http://www.diyelectriccar.com/forums/faq.php
Old 07-20-2012, 11:40 AM
Beemer Beemer is offline
Beemer is on a distinguished road
Tim, can't you simply use a mains switch?
