Originally Posted by JRP3
How about just running a small 12 volt battery, charged separately when you charge your pack?
On the tractor I'm already planning on charging each of the pack batteries individually with one 12V charger, it would just add to the charge time.
For summer use/play it isn't a problem but later on in the year I want to have lights on in the evening and I have worked out that I will need a larger battery then I want to give space for. I will have a small battery but want the converter to charge it from the pack.
Mainly I wanted to use one just to see what they are like to use before I get a bigger more costly one for the car.
So I have figured out that most automotive stuff expects 13.8V and that 12V may cause a slightly low voltage to be seen and can't charge a battery.
What effect does isolation and no isolation cause?
