Formula Hybrid - DIY Electric Car Forums
Old 05-15-2012, 09:10 AM
kishor5466's Avatar
kishor5466 kishor5466 is offline
kishor5466 is an unknown quantity at this point
Default Formula Hybrid
hey guys ,
for a car to accelerate and complete a distance of 200 under 6 to 8 seconds what type of motor can be used and tuned easily???
Old 05-15-2012, 09:51 AM
frodus's Avatar
frodus frodus is offline
Default Re: Formula Hybrid
200 what? feet? meters?
Travis Gintz
Electro Motive Force, LLC.
Old 05-15-2012, 03:39 PM
kishor5466's Avatar
Is it possible to achieve 200 meters under 10 seconds with any electric motor ???(If your car weighs around > 300kg approximately according to calculations)
Old 05-15-2012, 03:57 PM
frodus's Avatar
Do the calculations. Calculate the torque and power needed to accelerate a 300kg vehicle 200meters. Then come back and ask me if there's a motor that has that torque and power.
I can tell you YES, there is a motor that can do it, but it only races at 1/4mile at a time and does so in just under 7 seconds and goes 200mph.
If you need something for a longer race, things get more complicated. Cooling the motor becomes a huge issue.
Travis Gintz
Old 05-16-2012, 05:29 AM
Yabert's Avatar
Yabert Yabert is offline
Yabert will become famous soon enough
Yes... some electric Jr dragster on this site doing 1/8 miles under 10 seconds.
But under 6 sec will be a good challenge (imply a really good power to weigh ratio).
My Smart Fortwo high power! 57 000+ EV Km. Impulse 9, Soliton 1, chevy Volt battery
Old 05-16-2012, 05:40 AM
Tesseract's Avatar
Tesseract has a spectacular aura aboutTesseract has a spectacular aura aboutTesseract has a spectacular aura about
I'm replying here because I received a PM from you in which you asked me to solve your design problems. I don't mind helping people out but I'm not here to do anyone's homework!
If you are an engineering student then you ought to be able to figure out how to answer the above questions. First you need to determine the rate of acceleration given a distance and time, which which then also give you a final velocity. Next you need to figure out the amount of power required for the given mass and calculated velocity and acceleration rate.
After you've done all that you can then come here and ask for motor and controller recommendations. I can tell you right now that what you want to do is fairly simple and could easily be accomplished with low-end golf cart components.
Old 05-16-2012, 07:45 AM
kishor5466's Avatar
I have done the calculations before and the calculations are like this..........
m=400kg
t=8s
distance to be covered is 200m
since the initial velocity is 0 the acceleration will be 6.25m/s^2
hence final velocity will be 50m/s
so the output required will be 400*50*6.25=125kw
which is so huge?? Am i wrong in calculations?? or is the parameters taken are wrong??
or is it not possible to get the required outputs???
Old 05-16-2012, 08:54 AM
Tesseract's Avatar
m=400kg
t=8s
You said 300kg and 10 seconds to go 200m. That's quite a bit different from 400kg and 8 seconds... So which is it?
EDIT: 48kW for 300kg/10s/200m vs. 125kW for 400kg/8s/200m - that's the difference between only needing golf cart components or having to use mid-high level EV components.
Old 05-16-2012, 09:10 AM
kishor5466's Avatar
Yeah ....... so my calculations are correct ........... so i need the one for 400/8/200
Old 05-16-2012, 09:16 AM
iti_uk's Avatar
iti_uk iti_uk is offline
iti_uk is on a distinguished road
m=400kg
t=8s
300kg and 10s would give an answer of;
(a = 4m.s^-2)
(V = 40m/s)
48kW
Less than half of your last number.
Which target are you trying to hit?
edit: lol too slow
