i had to change the delta quiq chager on my 2008 zenn the model no i took off was 910 7201 ,the new one is 912 7200 was slightly different i had to change the leads and my old one had a 2 pin connector which goes to the curtis controller the place these wires connected to on the new charger is slightly different the charger works ok but the curtis controler is dead i assume the two small wires are some sort of safety device to stop you driving off still pluged in has any one else changed a charger on zenn cars and got round this problem thanks
