Old 06-12-2012, 03:59 PM
peskanov's Avatar
peskanov peskanov is offline
peskanov is on a distinguished road
Default Detachable BMS; should it work?
Hi,
Working in our conversion (a Mohave Quad) some time ago, we disliked the idea of having a BMS, with some many cables and conections, attached to the battery box.
Having worked a bit with RC LiPo packs, I thought we could emulate their system. That is, having the BMS outside the vehicle, along with the charger.
That way you avoid having a fragile circuit jumping in the Quad, but still get full cell balancing when charging.
Here there are some pictures of the components we are using to build our system:
Charger on the left, BMS on the right.
Another view,
Big, industrial plug,
The cells,
Now that we are building the pack, I am starting to have some doubts. So these are my questions to the experts here:
- Small wires from the cells to the BMS will be 50-70cm long. Could this length cause a voltage fall, fooling the BMS?
-Can frequent plug/unplug system affect the BMS (i.e. sparks from capacitors)?
-Is there any other problem I should know/prevent for this kind of system?
The components we have:
Charger: http://www.evassemble.com/index.php?...roducts_id=173
Cells: 24 Sinopoly LiFePo, 60AH. Bought from Mike Schooling on this forum.
BMS: http://www.evassemble.com/index.php?...products_id=46
Old 06-12-2012, 10:04 PM
Elithion's Avatar
Elithion Elithion is offline
Default Re: Detachable BMS; should it work?
I think you identified the issue correctly. But it seems to me that then you went about the solution in the diametrically opposite direction, actually exacerbating the problem.
Clearly, you've made a choice, and you're going to live with it.
Still, since you asked the question, let me suggest that a distributed BMS would have solved your concerns quite neatly.
Davide
Old 06-13-2012, 11:13 AM
dougingraham's Avatar
Small wires: If you are shunt balancing over these then the wires need to be heavy enough to handle the current. If the BMS measures the voltage with the balancing current turned off the length won't matter because there is no voltage drop. What does matter is that you will want a fuse on every wire connected to the battery at the battery end of the wire just in case.
Plug/unplug: Probably not sparks from capacitors as there shouldn't be any caps on the voltage sense lines. But static electricity could cause issues. If a mechanism is used to alleviate this your problem will be wearing out the connectors from the daily use.
Other problems: Lots of potential issues. The one thing that comes to mind is if you are going to public charge you wont have your BMS because it is back in your garage.
Having installed your BMS this way only covers issues during charging. The bigger issue is bricking cells when you over discharge. Charge is actually a non issue once you have balanced the pack and selected an appropriate CV point for your charger. Discharge is more difficult because you can't just pick a voltage and declare you will never go below that. Load changes this voltage. Your pack can easily see voltages below 2.0vpc under heavy loads and this is not harmful to the pack. This is why bottom balance as a protection mechanism works so well. You bottom balance and then it is very hard to brick a cell when you drive the car to the point where it wont move.
As an engineer I love data. I would like to see the voltage and temperature of every cell in the pack. I have talked myself out of a BMS because the data is useless for the normal operation of a car. It is useful only when things go wrong. A half pack voltage comparison will tell you when something is going wrong with a cell during charge and discharge. A bottom balance will protect you from yourself when driving the car. Undercharging the pack will protect you while charging. The additional wires and circuits is a reduction is reliability. My conclusion is that a BMS is not necessary with LiFePo4 chemistry cells and in fact may cause more problems than it cures. Ask yourself how many extra cells can you buy for the cost of the BMS.
Doug Ingraham
Rapid City, SD
Old 07-24-2012, 09:15 AM
peskanov's Avatar
Elithion, dougingraham, thanks for your expertise!
I wanted to try one charge before coming back to answer, and as usual putting all in place took much longer than anticipated.
I forgot to mention in my original post that we wanted strong Regenerative Braking and a cheap BMS system. That was one on the reasons for this experiment, as cheap BMS are no able to handle the higher charging currents (>50A).
Now, about our first charges. When we put the system to charge, we tested the voltage of several cells and compared to voltage on BMS plugs, to detect any voltage fall.
We have 24 cells. Cell 1 plugs on the negative wire, cell 24 in the positive.
What we found was important voltage falls in the extremes on the pack, but none in the intermediate cells.
Examples:
Cell 1 -> 3.44 on bms, 3.30 on cell
Cell 2 -> 3.33 on bms, 3.31 on cell
Cell 15 -> 3.31 on bms, 3.31 on cell
Cell 24-> 3.40 on bms, 3.31 on cell
Does anybody knows what could be going on here? Are our wires too thin/large?
Elithion,
you are right, but we have not found a BMS like that as cheap as we needed. We are using one of cheapest ones in the market, I think. Only e-bike and RC ones are cheaper!
dougingraham,
as you predicted, we have had no problems on pluging/unpluging the BMS.
We are thinking now about splitting charger & BMS, so at least we can load the charger on the Quad and be able to perform Opportunity Charging (without balancing).
Thanks for the fuses suggestion, we will implement it.
About undervoltage control, the controller should protect us (it has a setting for that) and we also have a cheap cell state display system. When a cell goes under ~3V it starts beeping.
The whole thing about bottom balancing is new to me. I have read some references before but I still have to really learn about it.
Old 07-24-2012, 09:20 AM
Elithion's Avatar
No, no, and no! Low voltage cut-off: a false sense of security
Davide
Old 07-24-2012, 12:10 PM
DIYguy's Avatar
DIYguy DIYguy is offline
Bottom balancing is worth reading about.
Also look at implementing a half pack bridge circuit, commonly known at the Lee Hart battery bridge, to compare two halves of pack voltage. A simple, effective way to spot problems early on.
Old 07-25-2012, 03:58 PM
peskanov's Avatar
Elithion,
well, as we cannot afford a good BMS, controller protection is better than nothing. We also have alarms in the cell monitors. Poor, but again better than nothing.
DIYguy,
we have 3 cell monitors, 8 cells each. We can (visually) compare the voltage of the 3 packs, and also inspect each cell to find any fault.
Old 07-26-2012, 02:29 AM
PStechPaul's Avatar
Lightbulb Re: Detachable BMS; should it work?
If you are getting higher voltages on the extreme ends of the pack, if it is truly the cell voltage, it could be a difference in temperature. But if it is just your readings that are off, I suspect that the BMS draws its operating power from these ends of the pack, and the measurement wire is shared with the power. It's easy to get 100mV or so of voltage drop which would skew these readings. If you can, run separate signal and ground leads, or use the heaviest wire you can for the power connections.
Do you have technical details of your BMS?
Old 07-26-2012, 07:02 AM
major major is online now
Sounds like you use the CellLog8s. Is that right?
Old 07-26-2012, 07:28 AM
skooler's Avatar
skooler skooler is offline
Hi Luis,
Great to see your project coming on
In my initial testing of some BMS systems I have found that voltages read differently on the cell terminals and on the end of the BMS wires.
The best method I found was to have all wires the same length no matter where the cell is in the pack - essentially find the longest lenth you will need and cut equal lengths for all your cells. This means that voltage drop is as even as you can make it. Also consistently use good connectors with good crimps, same type of wire etc..
I do think that the distributed version of miniBMS could do what you need it to.
Cheers,
