Old 09-04-2011, 05:49 PM
bruceme's Avatar
bruceme bruceme is offline
bruceme is on a distinguished road
Default DIY: Grid Tie Inverter
This isn't strictly EV, but I want a DIY solar install to offset my electric use.
I found this triac-based inverter. Honestly, it's a far cry from "pure sine". In fact, if everyone had one, the grid would go down. But it is intriguing... It appears to be the inverter equivalent to the capacitance charger. Low cost/PF. It works by using feedback from the grid to trigger gates in the correct order.
Obviously all the normal disclaimers apply... one should never connect one of these to the grid.. blah blah, but it's interesting all the same.
http://www.neo-aerodynamic.com/GridTieInverter.html
Total part cost for this 3kw inverter... $25. A 3kw true sine inverter is $1,800.
Thoughts?
Old 09-04-2011, 09:21 PM
gottdi
Guest
Posts: n/a
Default Re: DIY: Grid Tie Inverter
http://www.mwands.com/
Old 09-04-2011, 09:24 PM
gottdi
Guest
Posts: n/a
If you never connect to the grid and just connect to the inverter and only use things that can handle chop shop power vs pure sine wave then go for it. $25 bucks is cheap. I'd doubt that it would last long if you really pulled 3kw through it for any length of time. What batteries are you going to use and what charge controller do you plan on using. The posted link has some interesting things. I have been checking it out myself.
Pete
Old 07-10-2012, 11:58 AM
bo'sdad bo'sdad is offline
bo'sdad is on a distinguished road
I actually built one of these recently. I was getting very poor results until I changed the capacitor and it started climbing in watts. the problem was then the capacitor started getting hot and I couldnt tell is I was receiving 200 watts or inputting 200 watts. has anyone else tried to build on of these ?
Old 07-10-2012, 12:19 PM
Grid tie has to have a circuit to detect AC on the Grid side. it is not existent then do not connect. this has to be approved to tie to grid. it is because a line man my have killed the AC to work on the line and does not want to be electrocuted by someone Grid tie unit.
A second feature is a sync circuit so you use more than one to the grid at the same time. like 240 and 3phase.
Men and their Toys.
Old 07-10-2012, 06:26 PM
PStechPaul's Avatar
Thumbs down Re: DIY: Grid Tie Inverter
I call BS on the cheapo grid-tie inverter. About the only thing it can possibly do is pass AC through the capacitor to the battery. This will just alternately charge and discharge the battery with AC current. Since there is no current limiting other than the impedance of the capacitor, it could (and probably will) damage it.
If you have built one of these contraptions, measure the actual power drawn from the AC line. Then measure the true RMS current into and out of the battery. To see the actual power to and from the battery, you could use a wattmeter, or you could measure the DC current to or from the battery and multiply by the battery voltage. But unless the capacitor is shorted, or still charging, the DC current will be zero.
The http://www.mwands.com/index.php?main...ex&cPath=50_51 seems to show real grid tie inverters, at a more realistic price of about $1/watt. When I first saw the links, I thought it was for "magic wands", which you would need to get the cheapo inverter working.
Old 07-10-2012, 06:33 PM
Caps18 Caps18 is offline
Caps18 is on a distinguished road
It would be nice if there was a way for off-grid people to save lots on money on solar installs by DIY. I wouldn't trust it to work 7 days a week, 365 days a year in a grid environment however.
Plus, the enphase inverters are something like 96% efficient, I wonder what this one would be. Not that you wouldn't take some inefficiency to save $1800.
Old 07-11-2012, 06:55 PM
this inverter was not made to hook to a battery. and it does have island protection. the triac's are the protection. as soon as they loose power the system shuts down.
I have ordered a new set of capacitors and will post what I find when they come in.
Old 07-12-2012, 12:55 AM
PStechPaul's Avatar
Question Re: DIY: Grid Tie Inverter
OK, here it is:
Well, if it is an inverter then it gets DC from somewhere and adds this to the AC line which connects via transformers to the grid. So if there is no battery, where does the power come from?
The only possible way I can see something like this even remotely working, is to wait until the grid voltage is something like a few volts less than my DC supply (battery? solar cell? DC generator?) and then inject it into the grid. It might boost the waveform a little bit but unless you can keep up with the sinusoidal voltage variation sof the grid voltage, it would not contribute very much. So - maybe - you could convert the grid power to a step waveform where it does not go to zero but instead rides at the DC voltage until the zero crossing, and then get a negative DC level by reversing the battery connection until the voltage again rises beyond the DC level.
But the circuit shown does not and cannot do that. You cannot pass DC through a capacitor. So, unless I can see some meter readings and at least a basic explanation of what it's supposed to do, I remain skeptical at best. Show me!
Old 07-12-2012, 01:53 AM
the circuit as you laid out won't work.
Second if grid tie you don't have the sync circuit to match the grid with the AC generated, not with this circuit though.
first stage is a DC to DC that gives you the source to then use PWM to create a sine wave. The Sine wave is created by feeding the PWM into Inductors.
so you need hardware to create and adjust the PMW that will eventually be your output.
you can do this discrete or CPU.
The inverter I built, is supplied by 390 VDC battery pack. so no DC-DC is necessary.
it supplies 110/240 AC output but not grid tie.
Men and their Toys.
