I am looking for you opinions as to what would be the best drive system for the performance and abilities I am looking to get in an EV. You can also read my thread, EV Rally Car, here
http://www.diyelectriccar.com/forums...-car-5172.html to get an idea of what I a trying to do.
What I want out of my EV listed in order
1. Acceleration, I would like to get around 0-60 in 4 sec, or less
2. Handling, I want the car to handle as well if not better than the ICE version.
3. Range, I would like to get about 100 mile under normal diving conditions.
4. Top speed, This isn’t that big of a concern but I would like around 100 mph.
And the car I plan on using will be a 95 Subaru Impreza it is a popular Rally car and I already own one, you can also go here,
http://www.proev.com/ to see an already converted 95 Impreza.
Option 1, single motor
In this option I would use I single AC motor connected to the Subaru AWD drive train which would include a 6 speed transmission.
Benefits in my opinion, good acceleration this gear box is already geared for it, having a 6th gear could help with range on the highway and allow a good top speed, handling about the same as ICE, easy of conversion.
Negatives in my opinion, this would mean more moving parts more things to break.
Option 2, Duel motors
In this option I would use 2 AC motors, each one powering its own set of wheels, basically the same as the proev rally car. Benefits in my opinion, better AWD handling and better control of what wheels the power is going to, less moving parts less to beak down.
Negatives in my opinion, possibly less acceleration and lower top speed being locked into one gear, range may also take a hit, more difficult to convert.
Option 4 Quad motors
I this option I would use 4 AC motors each one connected to its own axle, I would do this instead of wheel hub motors to reduce un sprung weight. Benefits in my opinion, possibly the ultimate in AWD handling and control, It could even allow tank like turning abilities by running the right side motors clock wise and the right side counter clock wise it could literally spin on a dime.
Negatives in my opinion, again being locked into a single gear could hurt acceleration, top speed and range, much more difficult to convert.
And on a side note as I use more motors the smaller they would be, so I am not thinking of trying to cram 4 full sized motors in the car.
