Old 11-21-2009, 08:31 PM
shoup shoup is offline
shoup is on a distinguished road
Default E-E30 BMW Build
I have been working on my car for a while and using this forum as one of my primary references. I thought it was about time that I posted my progress and documented my build.
Donor car: 1990 BMW 325i
Voltage: 156V
Batteries: 13 12V AGM Lead Acid
Range Target: 30+ miles
Top Speed: 70+mph
I bought the car in February, but didn't really get into the build until September. I spent the time from February to September finding parts and designing some of the adapters, couplers, etc.
I am going to be attaching quite a few pictures. Below is a pic of the car as I got it, without the engine. I cleaned up the engine bay and removed the sound deadening material.
Old 11-21-2009, 08:42 PM
Default Motor Adapter Plate
I bought some recycled 1/2" aluminum plate off Dr. Bill that had vulcanized rubber on one side to use for my motor adapter plate. I did some calculations and 1/2" aluminum is plenty thick for the stresses it will be seeing. I am also going to be using a couple pieces of 3/4" thick aluminum as a spacer to complete my adapter and put the motor where it needs to be with respect to the transmission.
I attached the drawings I made for the plate and the assembly.
Old 11-21-2009, 09:02 PM
Default Re: E-E30 BMW Build
I am going to be keeping my clutch. I would like to autocross this car just to raise some eyebrows so I want to be able to make quick shifts if needed. I had the flywheel lightened & ring gear removed by a machine shop. I wish I had weighed it before I took it in, but too late now.
I wanted to maintain the pilot bearing that the end of the transmission shaft slides into to ensure the transmission and motor are aligned properly. The problem is the pilot diameter in the Warp 9 motor is not the same as the pilot on the BMW crankshaft. I found a bearing with an OD the same as the Warp pilot diameter, but it didn't have the same ID as the transmission shaft. I found a some tubing that had the same ID as the transmission shaft and an OD that would fit in the bearing. In the end it all fit very tight and there was no slop.
I had my motor coupler machined out of 4130 at a local machine shop. The 1/4" keyway should be sufficient with a 1/4-20 set screw to hold it all together. I also made a spacer to position the coupler the correct distance from the bearing on the electric motor. I found that a coupler for 1" copper pipe has a 1.125" ID which matches the motor shaft. This setup allows the clutch force (only ~400lb) to be transferred to the drive end bearing instead of the shaft. The clutch will hold the coupler in position from the other side, so all the set screw does is keeps the keyway from sliding out.
File Type: jpg lightened flywheel friction surface.jpg (58.0 KB, 29 views)
File Type: jpg flywheel installed and pilot bearing.jpg (62.0 KB, 28 views)
File Type: jpg sleeve for pilot bearing on transmission shaft.jpg (76.4 KB, 27 views)
Old 11-21-2009, 09:12 PM
Default Motor Bracket
I decided I wanted to keep the existing motor mount points and mounts that BMW used. To do this I made a bracket that bolts onto the front of the motor at one end and bolts to the motor x transmission adapter plate at the other end. This ended up being a more complex project than I anticipated, but it should work out well. I did not want my motor to be rigidly mounted to the frame of the car. By keeping the motor mounts it is somewhat isolated, just like the ICE was. I also took this route because I don't completely trust the band clamps that others use to hold the motor in place.
Old 11-21-2009, 09:22 PM
Default Motor Fitment
One issue I ran into is the placement of the motor. My goal was to have the motor positioned so that the transmission was in the same place and at the same angle as with the ICE. When in this position the Warp9 blows right through the power steering rack and the subframe/crossmember. The interference is ~80mm (3"). The power steering rack sat higher than the crossmember so I decided to drop it down ~.5" to put it at the same height. This would allow me to position the motor closer to where I wanted it, but it would still be at a slight angle. After test fitting the motor I do not think the angle difference is going to be an issue with the u-joints on either side of the driveshaft. To drop the power steering rack i cut up the brackets, bent them down and then welded filler plates back in. I don't even think it will affect my alignment, but I'll check before I get the car on the road.
Old 11-21-2009, 09:35 PM
Default Controller & other parts
I decided to go with the Logisystems 156V 1000a controller (refurbished). I hope it works when I get around to hooking it up.
The motor I am using is the Warp9.
I also attached some pics of some misc electrical parts I got in the other day. Westach voltmeter and ammeter, cheap vacuum pump from Surplus Center (http://www.surpluscenter.com/item.as...=1&item=4-1801), shunt, 500A fuse, relays.
The vacuum pump is for the power brake booster. I'm not sure if this pump will be sufficient, but it was 10x cheaper than other pumps out there and thought it would be worth experimenting with. I may run 2 if it can't keep vacuum built up for the brakes.
Old 11-21-2009, 09:47 PM
Default Batteries
Right now I am waiting on some parts and trying to figure out what batteries I am going to use. I wanted to use LiFePO4 but they are not going to fit into the budget right now so AGM will need to work. I did not want to worry about adding water to flooded batteries, and need to mount a few on their side. I also don't want to worry about high discharge rates of 5C+ for short periods.
I plan on putting 4 batteries under the car where the gas tank was, 5 or 6 in the trunk and 3 or 4 in the engine bay.
Here are the options I am looking at right now:
Exide MC31
Deka 8A31DTM
Deka 9A31
Trojan 31AGM
Optima SC31DS
All the batteries are group 31. All of them have a capacity @ 20 hr of ~100AH, except the Optima (75AH)
I'm also still working on choosing a charger.
Old 11-22-2009, 11:09 AM
80N541's Avatar
80N541 80N541 is offline
80N541 is on a distinguished road
Send a message via MSN to 80N541
great job
continue posting pictures ^^
"Anybody who want to make a revolution shouldn't grab a gun.
Let's go and start working to change the world by using science and technology"
Stanford R. Ovshinsky.
Old 11-23-2009, 11:24 AM
Thaniel's Avatar
Thaniel Thaniel is offline
Thaniel is on a distinguished road
Nice work.
I like your solution on the input shaft bearing. Do you have details on the part#'s used? I'm using a bushing and a bearing would be better but ran into the same issues you did.
Converting a 3 series BMW to EV. Thread:
http://www.diyelectriccar.com/forums/showthread.php/and-so-begins-17727.html
Blog (has more part#'s): www.ev-36.blogspot.com
Previous Engine swap experience:
2002 LS1 V-8 (think corvette) and 6 spd manual into a '93 3-series BMW (daily driver) http://www.ls1bmw.blogspot.com/
2000 Nissan Maxima V-6 and 350z 6 spd manual into a '91 Rx-7 (sold) http://www.v6rx7.blogspot.com/
Old 11-23-2009, 04:15 PM
Originally Posted by Thaniel View Post
Nice work.
Here are the parts I used, they were from Mcmaster-carr:
5905K23 Needle Roller Bearing, 1/2" shaft, 11/16" OD
8859K33 Brass Tube, 1/2" OD
I have a few pieces 1' long pieces of the tube left. If you want one PM me.
I would recommend using a bearing for transmission pilot. I don't think a bushing is going to cut it.
