A few pics from earlier:
My motor face bracket and my four-slot encoder wheel which I use with an IR emitter/detector pair as my tach pickup:
I had a 1/2" thick spacer ring waterjet cut from steel, with a slot cut for the AC50 encoder cable, but I had to split that ring in half again because I didn't have the space to assemble it as a whole ring.
Half my trouble was that the AC50 has 1/2" NC threaded holes, but the kit I received from CanEV had 7/16" bolts- which FIT in those holes, just not tightly, and dumb@ss here didn't notice! D'oh! I replaced all of them with the correct 1/2" NC bolts and with this spacer plate, now my motor is mounted solid as a rock! Transmission shifter doesn't move at all with 500 A of forward current or 200 A of regen.
The doorskins consist of vinyl-wrapped Masonite pressboard- not even the good tempered stuff, just cheap crap wrapped with cheap vinyl- don't know if these were original or not, but they got wet and destroyed during storage.
I made a replacement of the inner doorskin from Masonite again, but this time I coated it on both sides with a generous amount of Danish oil before installing it. It has lots of cut-outs for bolt or screw holes and other features- it serves to flatten out the door panel to make it easier to fit something more or less flat over top. Here it is on top of my outer doorskin.
I used 1/4" thick marine grade teak plywood intended for use in boats for my dash- two pieces laminated together to make the dash. Minimum order was 1/2 sheet, so I had just enough to make two doorskins from this. Unfortunately it is VERY stiff, so I had to cut some sawkerfs about 1/2 way through it every 1/4" or so at two points in order to allow it to flex enough to fit the curvature of the door. Even so, this requires quite a bit of force to hold it flat, which is beyond the limits of the hidden fasteners which normally hold on the doorskin.
