Old 04-16-2009, 12:29 AM
BobDiode BobDiode is offline
BobDiode is on a distinguished road
Default Ebike Alternator Motor DIY
NEW 8 hp Brushless motor that weighs 10 pounds and costs under $300.
Old 04-19-2009, 05:53 PM
nozza36 nozza36 is offline
nozza36 is on a distinguished road
Default Re: Ebike Alternator Motor DIY
BOBDIODE , you are a star ! i've been slowly planning a bldc
motor build but was worried about what to use as a main shaft for the rotor , you've just given me the perfect solution for a sturdy build ,
i'm off to the scrapyard to pick up a lorry alternator !
MANY THANKS !
Old 04-19-2009, 08:57 PM
MANY THANKS !
With a little machine work on the shaft two of the shorter housing halves can be used with a 17 x 40 mm bearing on each side. Good Luck!
http://www.hydrogenappliances.com/cores_and_coils.html
Old 09-03-2009, 12:20 PM
gostadler gostadler is offline
gostadler is on a distinguished road
Smile Re: Ebike Alternator Motor DIY
BobDiode sure came up with a good idea.
Has anyone thought of using one of those old Chrysler Corp pancake alternators, some were like 100 amps, reason is, the rotors are very large in diameter and the same magnetic field / current might give you a very much higher torque because of the leverage advantage of the large diameter rotor.
gostadler@yahoo.com
Old 09-03-2009, 03:50 PM
You need a PM rotor to make it worthwhile.
You can buy a brand new PM alternator with the strongest magnets available on E bay for under $200. 1/10 of it's power will flip over a bicycle.
Old 10-27-2009, 07:39 PM
Rollie Rollie is offline
Rollie is on a distinguished road
Does this controller pictured need position sensors or is it sensorless? If it needs position sensors would it work to take an inexpensive rc motor and marry it to the back of the alternator for a simple position sensor?
Old 10-27-2009, 11:07 PM
The Castle Creations HV 45 amp ESC is Seensorless and programable. A 3 wire hook up to the 3 phase wires.
Old 11-02-2009, 06:33 AM
Fujiyama1 Fujiyama1 is offline
Fujiyama1 is on a distinguished road
HI guys , new to the scene, are you converting the lorry alternator into a 3 phase motor , do you need some feedback from the shaft
re
Barry
Old 11-02-2009, 07:12 AM
hi yes it does need feedback , is it easy to build
Barry
Old 11-02-2009, 02:33 PM
Barry
A sensorless controller is all you need. If you make a magnetic PM rotor or buy a Delco PM alternator the PM rotor is already installed and there is no need to waste power energizing the field coil.
If you do want a sensored controller to commutate the rotor you must make a hall sensor board using three $1. hall sensors that can be epoxied to a fiberglass board and mounted in the right place for 60* timming.
This is a small 5 lb Ford PM Alternator / Motor with a hall sensor board and hall sensor controller used for a Electric bike that goes 45 MPH.
http://www.youtube.com/watch?v=El52vYPIEC0
The picture below is a Delco with and without a PM rotor. Notice that with the Claw Pole rotor without a PM rotor needs a pill magnet disk used to trip the hall sensors. A sensorless ESC is much eaiser and does not need hall sensors or a commutation disk.
