DIY Electric Car Forums > Production EVs and Hybrids > Production EVs
Old 05-08-2009, 10:08 AM
CroDriver's Avatar
Default Electric Porsche conversions
http://www.electricporsche.net/
This is a 911 based, respectable performing EV with (2) 11" motors,(2) 2000 amp controllers, 336volts.Over 2000 ft. lbs of torque for a fraction
336V X 2000 A = 672 kW
672 X 2 = 1.344 kW
16KWH - with 60 mile range per charge............................................ ................................................$1 6,000
32KWH - with 120-150 mile range............................................. .................................................. ......$28,800
64KWH - capable of over 200 mile range............................................. ..............................................$57, 600
How long does it take to charge? That really depends on how many amp hours that you took out of your pack last time you drove the car, what voltage and amperage you are putting it back in at. It can be from 20min-2 hours on 230volt. 10-40amp chargers typically are used on board. A solar collected, higher voltage set of batteries could be connected, ex.- an Ev-Carport, to the Ev set and move that energy at 250amps, or in about 5-10 min. When I plug in my garage its generally filled back up in 20 min- 2 hours.
LOL
Some of the cars on the photos have mufflers, the cars that are offered are fake (kit cars, not real Porsche)...
What do you guys think about this?
Old 05-09-2009, 12:34 AM
Default Re: Electric Porsche conversions
RUF's conversion as seen in some car mags, is soo nice.
http://www.greencarsite.co.uk/GREENN...orsche-911.htm
hmmm i recognise those cells :P
