Old 04-16-2011, 01:03 PM
Salty9 Salty9 is offline
Default Emergency Responder Warnings
I was reading about the Chevy Volt and saw that they had very explicit instructions about disarming the car in emergencies. Similar instructions appropriate for an EV could make things safer for occupants, first responders and could save equipment from unnecessary damage.
Old 04-16-2011, 07:01 PM
Duncan Duncan is online now
Default Re: Emergency Responder Warnings
Good Idea,
I intend to have a manual disconnect to separate the pack from the vehicle
and an intermediate manual disconnect (Anderson connector?) to split the pack into two segments
Instructions to Emergency Services
(1) - Pull big red lever - in front of handbrake
(2) - under the bonnet - pull Red Handle - marked Emergency disconnect
Old 04-22-2011, 10:29 PM
Lordwacky Lordwacky is offline
Lordwacky is on a distinguished road
Some one told me once that EMS responders in the US are being trained to look for large orange cables leading to the controller and/or batteries and to cut them with insulated cutters.
Old 04-23-2011, 01:40 AM
I can't help thinking that that would make the danger worse as there would now be an uninsulated high voltage end flopping about
Old 04-23-2011, 02:15 AM
jackbauer's Avatar
I think i spotted on a forum last year that certain parts of canada had banned ev conversions then changed their minds but specified a large warning sticker had to fixed to the car. I wonder if we could get those?
www.evbmw.com
www.e39ev.com
Old 04-26-2011, 08:13 PM
dtbaker's Avatar
dtbaker dtbaker is offline
if you have a picture, lots of the vinyl sticker shops can copy and make'em, for ya. However, I think a scarey looking sticker might scare off a Responder when you most need it!
The key I think is for YOU to build a vehicle with multiple safeties like:
- mid-pack fuse - quick acting
- main circuit breaker - slow acting
- manual pull disconnect - reachable from driver's window and seat
- inertia switch on main contactor/controller
...probably some legislated standard like the the manual pull disconnect MUST be near the driver's left knee and have some standard color/graphic so it can be accessed from driver's window by Responders....
and some mechanical safety standards, as much as I hate regulation, for our own good like:
- some standard sticker/emblem on exterior of driver's door indicating vehicle has high voltage
- main battery cabling from pack to motor must be routed under the center of the car to
avoid 'jaws of life' that typically cut doorsills and pillars
- batteries terminals and bus bars must be covered to prevent accidental shorts
Dan
Old 04-26-2011, 09:07 PM
The driver's air bag firing should trigger a circuit breaker.
Old 04-26-2011, 09:14 PM
dtbaker's Avatar
Originally Posted by Salty9 View Post
The driver's air bag firing should trigger a circuit breaker. Saying this, I have no knowledge of air bags or the way they work other than a novel I read claimed the explosive material was very poisonous.
the whole idea of an inertia switch in the main contacter loop is exactly this. in an impact strong enough to deploy an airbag, the main would open... just like the original design cuts power to the fuel pump. no need to tie it to the airbag system. easy to add, even in pre-airbag cars.
Dan
Old 04-26-2011, 09:51 PM
I should have thought of that. Maybe we can get Woodsmith to make a sticky to keep the recommendations in one spot.
Old 04-27-2011, 07:37 AM
Woodsmith's Avatar
Spam Busting Admin
I have made the thread a sticky, for the time being.
Please use this thread for specific ideas and solutions and not for general discussion, debate and other unrelated banter.
Thank you,
Admin
