Old 07-21-2012, 11:57 PM
Default Re: [EVDL] And yet another floodie to CALB?/Lithium longevity.
[quote]Lee Hart wrote:
>> Why not try just a few lithiums in series with the rest of a
>> lead-acid pack... When you charge, use a BMS to prevent the
>> lithiums from overcharging. Give it a year, and see how well the
>> lithiums are actually performing.
Steve Clunn wrote:
> I did something like this with one cell added to my lead acid pack
> just to see how it would do. I quickly noticed that the lithium
> cell needed less ah put back in than the Hawker lead acid. I
> don't think the battery management or something that shuttles an
> amp is going to be enough, the lead acid batteries will not get
> enough ah to get charged.
That makes sense. The BMS would have to be able to bypass however many
amphours were needed to finish charging and equalizing the lead-acids.
The little sub-amp BMS boards can't do it. It would require something
that can handle whatever your charger's finishing current is. If you're
running 6v golf cart batteries, that could be 5 amps!
> You could use a separate charger for your Lithium cells.
That would be a better option for a charger with a high finishing current.
Results! Why man, I have gotten a lot of results. I know several
thousand things that won't work. -- Thomas A. Edison
Lee A. Hart http://www.sunrise-ev.com/LeesEVs xxx@xxx.xxx
Old 07-26-2012, 05:35 AM
[quote] Peter C. Thompson <xxx@xxx.xxx>wrote:
> I've been driving my Porsche 914 as a daily driver since April 2010. I
> currently have 5500 miles on the batteries. Round-trip is 36 miles -
> but I don't drive the electric car every day. The batteries are CALB
> 60Ah (108 of 'em).
> So far, the batteries do not seem to be drooping, but that's only 2
> years worth of driving. At least it is a data point for you.
Another one: 2.5 years, 34k miles on CALB 180AH - I use about 1/2 the
capacity on my commute, obviously more on occasions.
Has survived one severe winter in use at -10 without heating or insulation.
No noticeable change in voltage sag or range since new, although I admit
I've never tried to push it to the ultimate range (somewhere over 100
miles).
My car can only pull 1.5C though, which might help.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120726/61d6dbb4/attachment.html
Old 07-26-2012, 08:06 AM
I do believe average C-rate and maximum C-rate should be kept as low as
possible for long battery life. This means big batteries or lots of them
and preferably both.
[quote] Evan Tuer <evan.xxx@xxx.xxx> wrote:
> On Sat, Jul 21, 2012 at 4:45 AM, Peter C. Thompson <xxx@xxx.xxx
> > 60Ah (108 of 'em).
> miles).
> URL:
Marcus Reddish
*North Valley Systems LLC*
Stevensville, Montana
406-360-8628
northvalleyev.com
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120726/d9fc0c10/attachment.html
Old 07-26-2012, 11:35 AM
I just took one car for routine checkup. EV odo 80.000 km and with LFP
since 2005. Will test the capacity of the cells since the car has been
working like a clock.
I put up some pics at FB site.
https://www.facebook.com/TransitionCompany
-akkuJukka
http://www.google.com/profiles/jarviju#about
2012/7/26 Marcus Reddish <marcus.xxx@xxx.xxx>:
>> > 60Ah (108 of 'em).
>> miles).
>> URL:
> Marcus Reddish
> 406-360-8628
> northvalleyev.com
