Old 07-26-2012, 03:36 PM
Default [EVDL] Banding Winston/Thundersky Batteries
Anyone know if there would be a problem banding up to twelve (12) 400 Ah
Winston/Thundersky batteries together? I am aware that they need to be
banded with the provided jigs so that they do not bulge/deform as they heat
under use. When I ordered them, the most batteries that could be banded
together is six. But I assume this limitation is due to portabiliy issues:
The jigs have carrying straps and six batteries is already about 180 lbs;
anything greater than this would be difficult to lift. For installation
into my conversin project, optimally I would like to band up to twelve
batteries together; this would allow inserting one more battery into two of
my battery boxes (the jigs themselves take up to 3/4" between banded sets of
batteries). Compressing twelve (rather than the maximum six) into a single
jig should work fine for keeping them from bulging or deforming, but would
this cause any other problem? Like excessive heat buildup in the middle
batteries? Any advice anyone can offer on this issue would be greatly
appreciated.
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/Banding-Winston-Thundersky-Batteries-tp4656789.html
Old 07-27-2012, 04:28 AM
Default Re: [EVDL] Banding Winston/Thundersky Batteries
Hi George,
There has been a lot of comment on the EVDL regarding swelling of LiFePO4 cells. It appears that if you do not abuse them they will not swell. By abuse, I mean specifically over-charging them. Apparently over-discharging does not cause swelling - it just destroys the cell. So, if you have a BMonS to prevent over charging and/or a BManS that works properly and does not cause over charging whilst balancing, then banding is not needed as the cells will not swell.
That said, I prefer to band cells as it means that the interconnects on a sub-pack do not put strain on the cell terminals and you can use the much cheaper layered, solid interconnects rather than braided ones. It also makes it easier to handle groups of cells.
The downside is that you can't stash the cells individually away into nooks and crannies in a tight installation situation.
How many and what type of band are you going to use? I ask as if you were going to use the plastic strapping type stuff then I would think you would need to use at least 8 straps but if using the standard metal ones, you may find they won't be taught enough to hold 12 x 400Ah cells together such that they won't move relative to one another when being handled as a pack - unless you keep them all on a level pallet or something.
When I strapped my 8 x 160LFPs together with 5 plastic straps even quite tightly, when lifted at each end, the cells tended to sag a bit (1/4") in the middle and twist as well. They all sorted them selves out when put down again but I could imagine the ribs locking out of sync or something equally annoying which would probably mean taking the banding off to correct!
One thing you could do to prevent that is to insert some pieces of wood or plastic just the right size to be a snug fit into the rectangular hole that 2 adjacent case grooves make. This would then 'lock' the 2 cells and prevent movement between them. You would only need a couple of these per adjacent cell pair.
Heating really won't be an issue unless you intend to race your EV or you live in Arizona (apparently) especially with 400Ah cells as I imagine the max continuous current draw will be less than 1C. Consequently, I doubt you will see any heating at all - maybe a few degrees at most. Keeping them warm in winter is another matter.
Good luck and keep us posted. EValbum page?
Regards, Martin Winlow
Herts, UK
http://www.evalbum.com/2092
www.winlow.co.uk
> appreciated.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/9090ac44/attachment.html
Old 07-27-2012, 05:35 AM
> appreciated.
I'm pleased to see someone else using large cells! How many total?
EVAlbum page? Ah! Here it is:
http://www.evalbum.com/4014
34 cells, 43kwh! IMHO, a great configuration. You might approach 200
miles. With my 48x260ah, I can do as much as 180 miles. With careful
driving. And you will have regen!
I'll give you my battery configuration story. Perhaps you will find
something of interest in it.
My Hyundai, http://www.evalbum.com/2314 , was initially configured with
5 cell blocks in one large array. 45 cells, 15x3, or three blocks by
three blocks. The handling was alarming; any speed over about 60 mph
felt unsafe. There was space to move the whole battery forward about
6" but I wanted to do better. By strapping all cells in a tier
together, I could save a couple of inches. Also the farther forward,
the greater the available width. So, I could get 20 cells in the most
forward tier and 15 in the second, leaving 10 in the rear. I had steel
battery frames constructed for each of the 3 tiers; the battery is well
restrained. My intention was to shim one end of each tier so that the
battery frame served for the cell compression. That didn't turn out as
I wanted, the cells are strapped with Harbor Freight load straps that
can be cinched down, two straps on each tier. Original aluminum
bearing plates are used at each end of each tier.
My evalbum page has two photos of the original configuration and three
of the new. Unfortunately, the Harbor Freight strapping was not
installed at the time the photos were taken. I suffered a couple of
swollen cells before the straps were installed. The swollen cells were
likely due to BMS modules that were damaged in the re-configuration.
Last year, Steve Clunn added three more cells in the right side of the
trunk.
Debian3.1/GNU/Linux system uptime 9 days 19 hours 20 minutes
Old 07-27-2012, 07:25 AM
My battery configuration is 12 under the hatch; 12 under the rear seat (this
is where the gas tank was in my Pontiac Vibe, so no exhaust, brake, or
electical lines ran under the full-span of the seat); and 10 under the hood
for a total of 34 (pack voltage 120 V).
For the two sets of 12, I was planning using the orginal metal bands used
for banding (up to groups of six) but joining them with stainless-steel
"worm-gear" hose clamps of the same width. The batteries would then be
placed one-by-one into the jigs already in the battery box, the bands added,
and the hose clamps tightened to compress the batteries between the end jigs
into the 12-pack. So I won't actually need to physically lift the
twelve-battery packs at all; they will be assembled directly into each
battery box.
I appreciate the great idea of inserting a couple of square dowels between
each battery in the pack to keep them from shifting side-to-side. Winston
Battery provided solid-copper straps for terminal connections between
batteries in a pack. The straps are not long enough to reach over jigs to
adjacent packs, so this way I will have to fabricate fewer terminal
connections than if smaller-size packs were used.
For the ten batteries under the hood, I'll probably join the two current
five-packs into a single ten-pack, space permitting (I won't know for sure
until I get the electric motor/tranny in the car).
Also good to know that battery-heating in use should not be an issue. I'm
using the MiniBMS system to keep the batteries in the proper charge range.
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/Banding-Winston-Thundersky-Batteries-tp4656789p4656811.html
Old 07-27-2012, 08:45 AM
The batteries LIKE heat. They perform better when hot. I un-banded them
and re-used the end plates with cables and turnbuckles. I filed a small
rounded notch in the aluminum to soften the corner on the cable. Now the
turnbuckles can be cranked up super tight, but can also be easily loosened
for maintenance. There are 3 banks of 12, 10, and 8 batteries. They are
Thundersky LFP260ah cells. No problems after 2 years. Cell bulging is
from over or under discharge. They will be damaged whether they are
restrained or not.
On Thu, Jul 26, 2012 at 9:16 AM, George Wagner
> of
> appreciated.
> Nabble.com.
Marcus Reddish
*North Valley Systems LLC*
Stevensville, Montana
406-360-8628
northvalleyev.com
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/5cb24e2c/attachment.html
Old 07-27-2012, 09:26 AM
You'll get better performance out of them when they are hot - for a
short time. Heat will rapidly reduce their capacity though, killing
them much sooner than they would otherwise have lasted.
For all the comments that I've read about swelling only being a result
of over charging, I had a 100Ah Hi-Power cell sitting on the bench
that spontaneously swelled and was ruined overnight. I have no idea
what caused it. The terminals were not in contact with anything and it
was sitting next to an identical set of cells that were just fine -
all of them at 3.28 volts. I can only assume that it was a
manufacturing defect that was triggered by a change to horizontal
orientation after a year of sitting vertical.
- ian
On Fri, Jul 27, 2012 at 9:42 AM, Marcus Reddish
> restrained or not.
>> of
>> appreciated.
>> Nabble.com.
> Marcus Reddish
> 406-360-8628
> northvalleyev.com
Old 07-27-2012, 09:45 AM
George,
I don't think the Jubilee (as we call them over here in the UK) or worm gear-type clips will exert enough tension - unless you use a lot of them... one per cell case groove maybe.
Marcus' cables would be better but I don't know exactly which product he is referring to. Plastic strapping is easy and cheap and has the advantage of being quite elastic (obviously at considerable tension) and therefore is unlikely to cause any damage due to over-tensioning, unlike a steel system. My strapping can be seen here... http://www.winlow.co.uk/wychwood.co.uk/EV_Conversion_-_Part_2.html
As for BMS', I gather Willie McKemie has some considerable experience of that particular product - good and not so, I gather.
Tho I have not tried it, the Elithion's 'Lithiumate Lite' would be my choice but it would be somewhat more expensive than the MiniBMS - but much more useful in terms of cell monitoring/logging etc.
Sure, between sub-packs, you would have to use braided connects or lengths of cable.
Herts, UK
www.winlow.co.uk
> battery box.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/66c1e3d3/attachment.html
Old 07-27-2012, 10:25 AM
I've got string of 13 CALB 100Ah cells bounded by an aluminum plate on each
end. The plates fit snugly between the end cells and the aluminum battery
box itself. Holes drilled in the battery box allow 4 36-inch lengths of
all-thread to protrude through the sides of the battery box where they are
bolted in place from the outside, making the box sides themselves also part
of the clamping. Haven't had any trouble in 2 years. Plus, the 1/4-inch
all-threads act as battery restraints in case of a crash. I've got three
rows of cells in the front battery box fitted tightly that way, with the
all-thread running down the grooves between the cells. I think you could
turn the box upside down and the cells wouldn't fall out.
Bill
-----Original Message-----
Of Martin WINLOW
Sent: Friday, July 27, 2012 9:41 AM
Subject: Re: [EVDL] Banding Winston/Thundersky Batteries
George,
of cable.
Herts, UK
www.winlow.co.uk
> (this is where the gas tank was in my Pontiac Vibe, so no exhaust,
> brake, or electical lines ran under the full-span of the seat); and 10
> under the hood for a total of 34 (pack voltage 120 V).
> used for banding (up to groups of six) but joining them with
> stainless-steel "worm-gear" hose clamps of the same width. The
> batteries would then be placed one-by-one into the jigs already in the
> battery box, the bands added, and the hose clamps tightened to
> compress the batteries between the end jigs into the 12-pack. So I
> won't actually need to physically lift the twelve-battery packs at
> all; they will be assembled directly into each battery box.
> between each battery in the pack to keep them from shifting
> side-to-side. Winston Battery provided solid-copper straps for
> terminal connections between batteries in a pack. The straps are not
> long enough to reach over jigs to adjacent packs, so this way I will
> have to fabricate fewer terminal connections than if smaller-size packs
were used.
> current five-packs into a single ten-pack, space permitting (I won't
> know for sure until I get the electric motor/tranny in the car).
> I'm using the MiniBMS system to keep the batteries in the proper charge
range.
URL:
hment.html
Old 07-27-2012, 10:45 AM
I like this idea. Question: what do you do from keeping the long sides from
bowing out? Do you put some brackets across the top and bottom at
intervals?
Peri
Of Bill Dennis
Sent: 27 July, 2012 9:16 AM
To: 'Electric Vehicle Discussion List'
Bill
Of Martin WINLOW
George,
of cable.
Herts, UK
www.winlow.co.uk
were used.
range.
URL:
hment.html
Old 07-27-2012, 11:15 AM
My box is wedged in pretty tightly, so I haven't had any problems with
bowing. But initially I had considered also running a piece of all-thread
from front to back by leaving a 3/16-inch gap between two cells close to
center. I had three pieces of aluminum about 1/3 the height of the cell, so
that starting at the top of the box between those cells it was:
Piece of aluminum
3/16 all-thread
Piece of aluminum
3/16 all-thread
Piece of aluminum
Hope that's clear.
Bill
Of Peri Hartman
Sent: Friday, July 27, 2012 10:36 AM
intervals?
Peri
Of Bill Dennis
Bill
Of Martin WINLOW
George,
of cable.
Herts, UK
www.winlow.co.uk
> packs
were used.
> charge
range.
URL:
hment.html
