FWIW,
A top balancer that really works automatically, every time you charge means
you never have to do anything to the batteries but use them to move the car.
In essence this means as most of us have been saying, a balancing system
with LiFePO4 is a good idea.
Sincerely,
Mark Grasser
-----Original Message-----
Of David Ladd
Sent: Tuesday, June 19, 2012 2:31 PM
Subject: Re: [EVDL] charger question - bypassing batteries
The last time I installed my cells, I charged them each individually up to
3.60v with a PowerLab 6 charger. I installed them all, drove a bit, then
charged them with my vehicle charger. My charger shuts off at 3.5vpc
average, and there were 10 or so MiniBMS red lights that were not on at end
of charge (on mine, the lights come on at ~3.47v). I figured they had to=
be
pretty close since I had manually charged them all to 3.60v, and just left
it be. About 10 discharge/charge cycles later, I checked. The same ce=
lls
were still not lighting up the MiniBMS lights. At that point I manually
brought them up with a power supply one cell at a time, and found they
required less than 1ah to get up to shunting (typical was about 15 minutes
at 2a). I don't think the MiniBMS is able to handle much balancing at all
(at least in my case when I'm only charging to 3.5vpc), but at least it will
make up for any cell balance difference due to it's own power draw.
Now all 48 lights are on at end of charge. I've also noted that over the
last few months, the same lights come on in the same order every time, and
the same cell is always the last one to light up. Not a lot of balancing
going on I don't think.
fwiw, it's easy to balance them with a power supply. You don't have to
disconnect anything, just set it to 3.6v open voltage, alligator clip it
across the single cell, and turn up the current to charge until the red
light on the MiniBMS comes on. You are now at 3.47v, monitor the cell ti=
ll
i gets to where you want it to be (in my case 3.5v), then shut off the power
supply.
Check again next charge cycle and repeat as necessary.
3D=3D=3D=3D=3D=3D
Email scanned by PC Tools - No viruses or spyware found.
(Email Guard: 9.0.0.1218, Virus/Spyware Database: 6.19940)
http://www.pctools.com/ =3D=3D=3D=3D=3D=3D=3D
3D=3D=3D=3D=3D=3D
3D=3D=3D=3D=3D=3D
