Re: [EVDL] ev computers??
----- Original Message -----
From: "Electric Blue auto convertions" <xxx@xxx.xxx>
To: "ev" <xxx@xxx.xxx.edu>
Sent: Thursday, November 19, 2009 9:49 AM
Subject: [EVDL] ev computers??
> Since I have been doing conversions the only thing I found out about the
> cars ICE, ECM is that it drives the speed-0, thats all its used for when
> you take out the ICE, the ECM has no more duties to do except the speedo,
> when Im done with the conversion i cut all the wireing while the car is
> running in gear and keeping an eye on the speed-o one set of wires at a
> time.
Yeah! Worked for ME, too. I snipped one wire at a time, checking all the
Jettas vital stuff; silly things like lights, signals , tail and Brake
applied lites. Got RID of the computer box and seemingly MILES of loose end
wiring!Jeddi have speedo CABLES, Still! On the S-10, we KEPT that aluminum
box mounted on the trux's right side fenderwell, as the SPEEDO worked when I
grounded THAT! We found ONE of the loose grounds floating around in the ICE
wiring. Mike can prune as he goes, I got the "Essentials" working! you can
DRIVE the truk and everything WORKS! Especially the Plaintive "Service
Engine" light! Engine is PROBABLY on the way to China, by now?No Traking no?
> When im done all i have is the speedo wireing to the ECM and some 12 volt
> inputs and grounds ABS uses a seperate ECM.
I GUESS most cars sorta work the same?
> Air bags dont use a ECM, its on impact switching and relays REMEMBER !!!!!
> keep it simple, just make it work,
> dont try and reinvent the wheel wayne ev-blue.com
Try NOT to, just turn the one's I got!
Bob
General support: http://evdl.org/help/
Unsubscribe: http://www.evdl.org/help/index.html#usub
Archive / Forum: http://evdl.org/archive/
