Re: [EVDL] Heating Core Relay Tackled
There exist two relatively simple solutions
that avoid having problems with breaking
high voltage DC:
1. the limit and overtemp (thermal fuse) are
wired into the DC that engages the contactor,
so when one opens then the contactor loses its
coil drive and opens.
2. the overtemp (thermal fuse) can be wired to a
"crowbar" which will short circuit the heater
so it blows the (DC rated!) HV fuse. This means
that the overtemp does not need to break DC, only
be able to withstand the DC as long as it is not
activated and carry the full current that blows
the DC fuse to protect the heater.
Cor van de Water
Chief Scientist
-----Original Message-----
Behalf Of EVDL Administrator
Sent: Sunday, August 19, 2012 12:54 PM
Subject: Re: [EVDL] Heating Core Relay Tackled
[quote]On 19 Aug 2012 at 14:22, Lee Hart wrote:
> Don't forget that you can't use the stock power switch, thermostat, or
> safety overtemperature fuse. They will fail on high voltage DC!
Thanks. I should have mentioned that. The thermostats (room
temperature and thermal limit) have to be rewired so they control the
contactor. If you leave them in series with the element, they'll weld
themselves the first time they try to open.
This is relatively easy with the room temperature thermostat. It's a
little more challenging with the limit thermo, which is usually crimped
right onto the element itself.
You'll also need a DC rated replacement for the thermal fuse (backup to
the limit thermo). I confess that when I did it, I sort of let this
slide, but you shouldn't.
David Roden
EVDL Administrator
http://www.evdl.org/
