Old 06-27-2012, 01:26 PM
Default [EVDL] Jerky Accelerator Cable
The under-hood battery box on my EV is real close to the firewall, necessitating having to make a sharp bend in the accelerator cable between the firewall and battery box to route it over to the pot box. It works, but the cable is real jerky, so it's hard to take off smoothly. The cable itself is metal wire inside plastic sheathing. Due to lack of any additional space under the hood, there's no place to put the pot box that would alleviate the bend. Any suggestions for helping the situation except drilling another hole in the firewall and moving where the cable comes through, or purchasing an electronic pedal?
Thanks.
Bill
Old 06-27-2012, 01:35 PM
Default Re: [EVDL] Jerky Accelerator Cable
Have you considered moving the potbox inside the vehicle?
> Date: Wed, 27 Jun 2012 15:24:08 -0400
> From: xxx@xxx.xxx
> To: xxx@xxx.xxx.edu
> Subject: [EVDL] Jerky Accelerator Cable
> Thanks.
> Bill
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120627/ffdfe208/attachment.html
Old 06-27-2012, 02:15 PM
I have considered it, but are the 3 wires from the Curtis 1231C controller isolated from pack voltage? If not, I don't want to bring pack voltage inside the firewall.
Bill
----- Original Message -----
To: EV List <xxx@xxx.xxx.edu>
Sent: Wed, 27 Jun 2012 15:31:41 -0400 (EDT)
Subject: Re: [EVDL] Jerky Accelerator Cable
> From: xxx@xxx.xxx
> To: xxx@xxx.xxx.edu
> Thanks.
> Bill
> smoothly.
You don't need to use a cable. Lots of EVs simply put the pot somewhere
under the dash, and operate it directly with the pedal. It's easy to
extend the potbox wires as long as necessary to reach the controller.
First they ignore you; then they mock you; then they fight you; then you
win.
-- Mahatma Gandhi
Old 06-27-2012, 02:35 PM
Sounds like a hazard to me. If it sticks enough to be jerky, what will it
be like in a year or two? Stuck accelerator?
Peri
-----Original Message-----
Of damon henry
Sent: 27 June, 2012 12:32 PM
To: EV List
> From: xxx@xxx.xxx
> To: xxx@xxx.xxx.edu
> Thanks.
> Bill
URL:
hment.html
Old 06-27-2012, 02:46 PM
It sticks only when being pressed. The return action is smooth. I also have a second, external spring on the PB6.
Bill
To: 'Electric Vehicle Discussion List' <xxx@xxx.xxx.edu>
Sent: Wed, 27 Jun 2012 16:09:44 -0400 (EDT)
Peri
Of damon henry
To: EV List
> From: xxx@xxx.xxx
> To: xxx@xxx.xxx.edu
> Thanks.
> Bill
URL:
hment.html
So - yo uhave a lot of tension on the cable to pull
against those two springs and the cable makes a sharp bend,
that is a prime candidate to wear through the plastic jacket
and rub heavily, causing the stickyness that you experience.
Easiest is probably a new hole and probably a new cable sheat.
If you can turn the cable sheat 180 deg around it could give
you some more life...
Cor van de Water
Chief Scientist
Behalf Of Bill Dennis
Sent: Wednesday, June 27, 2012 1:27 PM
Bill
it be like in a year or two? Stuck accelerator?
Peri
Behalf Of damon henry
To: EV List
> From: xxx@xxx.xxx
> To: xxx@xxx.xxx.edu
> Thanks.
> Bill
URL:
ttac
hment.html
Old 06-27-2012, 03:06 PM
Hello Bill,
Go to a large truck part store, something like Freightliner and see how
smooth there throttle cables work. You can actually bend then in a tight
circle and can pull or push them with your little finger.
There is also a lot of cable end attachments from rod end ball bearings,
adjustment spring returns and etc.
Roland
Sent: Wednesday, June 27, 2012 1:24 PM
> Thanks.
> Bill
Old 06-27-2012, 08:35 PM
depending on how your pedal is set up, you may be able to link the potbox
right to the top of the pedal itself and eliminate the cable. as the one
possible example, the photos below show how i did it on a 1991 ford escort.
sorry about missing caps btw, my computer configuration is a bit off tonight
and i have no upper case.
http://drmm.net/ev/images/pedal01.jpg
http://drmm.net/ev/images/pedal02.jpg
EVDL Administrator
[top]
[top]
[top]
