Old 07-27-2012, 05:45 PM
Default Re: [EVDL] PFC-30 Goes All Current-Limit on Me
No, I'm referring to the amperage knob. I don't have a meter on it right
now, but since the knob is at maybe 60-65%, the amps should be somewhere
around 20A or a little higher. The pack is lithium. The cutoff voltage is
set at 124.5V, which is about 3.45V/cell. Pack started out at 118V today.
I consider "halfway" to be when the white marker on the amperage knob is
pointing straight up.
1) Plugged in charger
2) Turned on charger breaker with amps down to zero
3) Slowly turned amp knob past halfway
4) Pack started charging
5) Measured voltage at 120.6V
6) Went inside for 2 or 3 minutes
7) Came back out to garage to find charger yellow limits LED blinking
This has happened to me in the past whenever I've tried to charge with knob
at much more than half way.
Bill
-----Original Message-----
Of Cor van de Water
Sent: Friday, July 27, 2012 5:09 PM
Subject: Re: [EVDL] PFC-30 Goes All Current-Limit on Me
what are you turning up? Output voltage?
What is the pack you are using and which voltage and current is the PFC30
delivering when you see it go into limit?
It may be normal behavior, it may not,
at this point we have too little info to judge.
Cor van de Water
Chief Scientist
Of Bill Dennis
Sent: Friday, July 27, 2012 1:39 PM
To: 'Electric Vehicle Discussion List'
Subject: [EVDL] PFC-30 Goes All Current-Limit on Me
If I turn my PFC-30 up more than about half way, it goes into current limit
mode in less than 2 minutes. There's plenty of air space around the
charger, the trunk is open, and the temp in my garage is 74F (23C).
Does anyone else have this problem? Usually it's not an issue, since I
charge at low current overnight. But this morning I was out and about, and
I wanted to charge the car again to take it downtown for the evening.
Thanks.
Bill
Old 07-27-2012, 05:55 PM
Mike, I don't understand your instructions. It's not the blue LED that's
blinking. It's the yellow current limit LED. The pack already cuts off at
the correct voltage of 124.5V. I have the charger dip switches set to have
the PFC-30 stop charging as soon as the voltage set point is reached. But
this is happening before the blue LED even comes on.
Bill
Of Mike Willmon
Sent: Friday, July 27, 2012 5:02 PM
Bill when the pack is largely depleted watch the voltage on a meter. See if
it stays out of current limit say when your pack is at 119v. Then watch
at what voltage the light starts blinking. If it stays off until 121v or
so then try adjusting the trim pot up slightly until it goes off. Then
repeat the trim process until you get it up to 124.5v. It sounds like its
doing exactly what it should.
[quote] "Bill Dennis" <xxx@xxx.xxx> wrote:
> Pack isn't reaching its voltage limit. Cutoff voltage is 124.5V.
> PFC-30 goes into current limit even if pack voltage is 121V or 122V.
> Yellow limits light is blinking. From the PFC-30 manual:
> "If the yellow LIMITS LED is blinking, then it is indicating that
> there is an over temperature condition and the charger is in thermal
> cutback mode."
> Bill
> Behalf Of Mike Willmon
> Sent: Friday, July 27, 2012 2:55 PM
> What pack voltage are you running? Are you running into a battery
> side current limit or a AC line side current limit? If your pack is
> reaching the regulation voltage rather quickly the current will be
> limited to honor that voltage regulation.
> I've never had the problem but I think that if the charger goes into
> thermal cutback you will get the megabright red LED warning light.
> Mike
> > current limit mode in less than 2 minutes. There's plenty of air
> > space around the charger, the trunk is open, and the temp in my
> > garage is 74F (23C). Does anyone else have this problem? Usually
> > it's not an issue, since I charge at low current overnight. But
> > this morning I was out and about, and I wanted to charge the car
> > Thanks.
> > Bill
> -------------- next part -------------- An HTML attachment was
> scrubbed...
> URL:
> http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/8020941a
> /attac
> hment.html
URL:
http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/34c17545/attac
hment.html
Old 07-27-2012, 06:06 PM
Bill,
Current limit and pack reaching voltage limit are two entirely
independent things.
Current limit is simply the charger reducing its output current below
the level
that you have chosen, because it cannot deliver the power and stay at a
safe temp
so it limits itself, which only means that you have to wait longer
before the
needed Ahs are put in.
The pack reaching voltage limit happenes towards the end of bulk charge
and this may take a little longer than you expect due to the reduced
charger current, but the voltage limit should not be affected by the
charger
cutting back in current - it will just take longer.
BTW, the name PFC30 means that it is limited to 30A at *either* input or
output,
whichever is greater, right?
Are you incidentally charging with an extension cord at 120V AV?
If the input voltage sags due to high resistance in the AC mains then
it could be that the input 30A is reached (and the charger will get hot)
when it is only drawing for example 90V x 30A = 2700W.
When it delivers current into a 120V DC pack, that means that it will
hardly be able to deliver 22A DC so if you commanded more than 22A
it might show a current limit not from overheating but because AC input
current is the limit?
Or are you charging from 240V AC?
Cor van de Water
Chief Scientist
Behalf Of Bill Dennis
Sent: Friday, July 27, 2012 2:33 PM
"If the yellow LIMITS LED is blinking, then it is indicating that there
is an over temperature condition and the charger is in thermal cutback
mode."
Bill
What pack voltage are you running? Are you running into a battery side
current limit or a AC line side current limit? If your pack is reaching
the regulation voltage rather quickly the current will be limited to
> limit mode in less than 2 minutes. There's plenty of air space around
> the charger, the trunk is open, and the temp in my garage is 74F
> (23C). Does anyone else have this problem? Usually it's not an
> issue, since I charge at low current overnight. But this morning I
> was out and about, and I wanted to charge the car again to take it
> Thanks.
> Bill
URL:
http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/8020941a/a
ttac
hment.html
You say "this is happening" - do you mean that the charger stops
charging
with the yellow LED blinking, not continuing it charging until it hits
the voltage set point (blue LED)?
Cor van de Water
Chief Scientist
Sent: Friday, July 27, 2012 4:46 PM
that's blinking. It's the yellow current limit LED. The pack already
cuts off at the correct voltage of 124.5V. I have the charger dip
switches set to have the PFC-30 stop charging as soon as the voltage set
point is reached. But this is happening before the blue LED even comes
on.
Bill
See if it stays out of current limit say when your pack is at 119v.
Then watch
or
its
> cutback mode."
> Bill
> Mike
> > Thanks.
> > Bill
> scrubbed...
> URL:
> /attac
> hment.html
URL:
ttac
hment.html
No, the charger is still charging, but the yellow LED is flashing, meaning
that it has reduced the current due to thermal cutback.
Bill
Of Cor van de Water
Sent: Friday, July 27, 2012 5:55 PM
You say "this is happening" - do you mean that the charger stops charging
with the yellow LED blinking, not continuing it charging until it hits the
Cor van de Water
Chief Scientist
Of Bill Dennis
Bill
Of Mike Willmon
Then watch
or
its
> cutback mode."
> Bill
> Mike
> > Thanks.
> > Bill
> scrubbed...
> URL:
> /attac
> hment.html
URL:
ttac
hment.html
Old 07-27-2012, 06:15 PM
Misunderstanding on my part. Bill said the yellow limit goes flashing.
When mine hits the voltage regulation point the yellow limit light goes
solid. That's how you adjust the voltage setpoint right. When the yellow
light comes in solid the charger is limiting current to hold the voltage
constant. But Bill said his limit light was flashing. So there may be
something wrong. Need to call Madman tomorrow.
[quote] "Cor van de Water" <xxx@xxx.xxx> wrote:
> Bill,
> independent things.
> the level
> safe temp
> before the
> charger
> output,
> Cor van de Water
> Chief Scientist
> mode."
> Bill
> Mike
> > Thanks.
> > Bill
> URL:
> ttac
> hment.html
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120727/eb6cdda0/attachment.html
Boy, I must be explaining things really badly if I'm coming across as not
even knowing the difference between current limit and reaching voltage
limit.
I am charging from a 220V outlet over a #8 cord. Charging is indicating
that it's going into thermal cutback mode, not that it's reaching voltage
set point.
Bill
Of Cor van de Water
Sent: Friday, July 27, 2012 5:53 PM
Bill,
Current limit and pack reaching voltage limit are two entirely independent
things.
Current limit is simply the charger reducing its output current below the
level that you have chosen, because it cannot deliver the power and stay at
a safe temp so it limits itself, which only means that you have to wait
longer before the needed Ahs are put in.
The pack reaching voltage limit happenes towards the end of bulk charge and
this may take a little longer than you expect due to the reduced charger
current, but the voltage limit should not be affected by the charger cutting
output, whichever is greater, right?
If the input voltage sags due to high resistance in the AC mains then it
could be that the input 30A is reached (and the charger will get hot) when
When it delivers current into a 120V DC pack, that means that it will hardly
be able to deliver 22A DC so if you commanded more than 22A it might show a
current limit not from overheating but because AC input current is the
limit?
Cor van de Water
Chief Scientist
Of Bill Dennis
"If the yellow LIMITS LED is blinking, then it is indicating that there is
an over temperature condition and the charger is in thermal cutback mode."
Bill
Of Mike Willmon
current limit or a AC line side current limit? If your pack is reaching the
regulation voltage rather quickly the current will be limited to honor that
voltage regulation.
I've never had the problem but I think that if the charger goes into thermal
> Thanks.
> Bill
URL:
ttac
hment.html
Old 07-27-2012, 06:25 PM
OK, that is very clear.
Does the PFC30 have a fan inside?
Could it be that the way it is installed
cause stagnant air inside and heating up
and can you notice the heating up on the outside?
It is possible that the current cutback circuit is
too sensitive, but more likely that it is working
well and there is indeed something getting hotter
than usual...
Success,
Cor van de Water
Chief Scientist
not even knowing the difference between current limit and reaching
voltage limit.
voltage set point.
Bill
Behalf Of Cor van de Water
Bill,
independent things.
the level that you have chosen, because it cannot deliver the power and
stay at a safe temp so it limits itself, which only means that you have
to wait longer before the needed Ahs are put in.
charger cutting back in current - it will just take longer.
hardly be able to deliver 22A DC so if you commanded more than 22A it
Cor van de Water
Chief Scientist
mode."
Bill
> Thanks.
> Bill
URL:
ttac
hment.html
Old 07-27-2012, 06:45 PM
It sounds like something must be wrong inside the charger. There's plenty
of air space around both sides of the PFC-30 (I can post a picture if that
would help) and the trunk is open, so the air probably isn't stagnant. I
can hear the internal fan running and feel air being sucked in on one end
and expelled out the other. I've sent an email to Manzanita Micro.
A J1772 charger has recently been installed near where I work, and I've been
hoping to take advantage of it to charger for 1/2 hour during lunch. But if
I can't put 30A into the pack, it won't do me much more good than the 15A
I'm already getting out of the 120V charge station in town.
Bill
Of Cor van de Water
Sent: Friday, July 27, 2012 6:23 PM
Could it be that the way it is installed cause stagnant air inside and
heating up and can you notice the heating up on the outside?
It is possible that the current cutback circuit is too sensitive, but more
likely that it is working well and there is indeed something getting hotter
than usual...
Success,
Cor van de Water
Chief Scientist
Of Bill Dennis
limit.
set point.
Bill
Of Cor van de Water
Bill,
things.
limit?
Cor van de Water
Chief Scientist
Of Bill Dennis
Bill
Of Mike Willmon
voltage regulation.
> Thanks.
> Bill
URL:
ttac
hment.html
Old 07-28-2012, 03:26 AM
Arrgh! I missed some posts, and I see that you are charging from 220 V.
Please disregard my earlier message.
View this message in context: http://electric-vehicle-discussion-list.413529.n4.nabble.com/PFC-30-Goes-All-Current-Limit-on-Me-tp4656822p4656859.html
