[EVDL] questions about Virginia HB 780 - DIY Electric Car Forums
Old 07-09-2012, 02:45 PM
Default [EVDL] questions about Virginia HB 780
SGkgYWxsLAoKSSBhbSBhYm91dCB0byBzdGFydCBteSBmaXJzdC BFViBjb252ZXJzaW9uICgxOTk3
IE1pYXRhKSBhbmQgSSBmb3VuZCBWaXJnaW5pYSBIb3VzZSBCaW xsIDc4MCB3aGljaCBpbmNsdWRl
cyBzb21lIHJlcXVpcmVtZW50cyBmb3IgQ29udmVydGVkIEVsZW N0cmljIFZlaGljbGVzIGluIG9y
ZGVyIHRvIHBhc3MgaW5zcGVjdGlvbiAodGFrZXMgZWZmZWN0IG luIE9jdCAyMDEyKS4gRG9lcyBh
bnlvbmUgaW4gVkEgaGF2ZSBrbm93bGVkZ2Ugb2YgdGhpcyBiaW xsPyBJJ20gd29ycmllZCBhYm91
dCBwYXNzaW5nIGluc3BlY3Rpb24gYW5kIHdhbnQgdG8gbWFrZS BzdXJlIEkgY3Jvc3MgbXkgdCdz
IGFuZCBkb3QgdGhlIGkncy4gCgpTcGVjaWZpY2FsbHk6CgpCdX JpZWQgaW4gSEIgNzgwIGl0IHN0
YXRlcwoKIlN1Y2ggY2VydGlmaWNhdGlvbiBzaGFsbCBiZSBvbi BhIGZvcm0gYXBwcm92ZWQgYnkg
dGhlIENvbW1pc3Npb25lciBhbmQgdGhlIFN1cGVyaW50ZW5kZW 50IGFuZCBzaGFsbCBzdGF0ZSB0
aGF0IHRoZSBpbnNwZWN0b3IgaGFzIHZlcmlmaWVkIHRoYXQuLg ooaWkpIHRoZSBmdWVsIHRhbmsg
aGFzIGJlZW4gcmVtb3ZlZCBhbmQgbm90IHJlcGxhY2VkOyIKCk nigJlkIGxpa2UgdG8gY29udmVy
dCB0aGUgdGFuayBpbnRvIGEgc3RvcmFnZSB0cnVuayBzaW5jZS BpdCBpcyBsb2NhdGVkIGRpcmVj
dGx5IGJlaGluZCB0aGUgcGFzc2VuZ2VyIHNlYXRzLiBJdCB3aW xsIG5vIGxvbmdlciBmdW5jdGlv
biBhcyBhIHRhbmsgYW5kIHdpbGwgYmUgY2xlYW5lZCBhbmQgcG FpbnRlZCwgYnV0IGl0IGlzIHN0
aWxsIHRoZSBzYW1lIOKAnHRhbmvigJ0uIEFkdmljZT8KCkFsc2 8gYnVyaWVkIGluIHRoZSBjb2Rl
IGlzCgoiMy4gQW4gZXh0ZXJuYWxseSBtb3VudGVkIHN3aXRjaC B0byBvcGVuIHRoZSBoaWdoIHZv
bHRhZ2UgY2lyY3VpdCBpbiBjYXNlIG9mIGFuIGVtZXJnZW5jeS 4gU3VjaCBzd2l0Y2ggbXVzdCBi
ZSBsb2NhdGVkIHdoZXJlIHRoZSBmdWVsIHRhbmsgZmlsbGVyIG NhcCB3YXMgbG9jYXRlZCBwcmlv
ciB0byBjb252ZXJzaW9uLiBBbnkgY292ZXIgcHJvdGVjdGluZy B0aGUgc3dpdGNoIG11c3QgYmUg
YWJsZSB0byBiZSBvcGVuZWQgZnJvbSB0aGUgb3V0c2lkZSBvZi B0aGUgdmVoaWNsZTsiCgpJIHdv
bmRlciBpZiBhbnkgU1BTVCBzd2l0Y2ggd2lsbCB3b3JrLiBUaG UgaWduaXRpb24ga2V5IGFscmVh
ZHkgc2VydmVzIHRvIGludGVycnVwdCB0aGUgY29udGFjdG9yIG ZvciB0aGUgYmF0dGVyeSBiYW5r
LiBJIHdhcyBnb2luZyB0byBqdXN0IGFkZCBhbm90aGVyIHN3aX RjaCBpbiB0aGUgZ2FzIHRhbmsg
ZmxhcCBhcmVhIHRoYXQgaW50ZXJydXB0cyB0aGUgMTIgViBvZi B0aGUga2V5IHN3aXRjaC4gSSB0
aGluayB0aGF0IGlzIHdoYXQgdGhleSB3YW50LiBBZHZpY2U/CgpBbHNvLCBsaWtlIG1vc3QgY2Fy
cywgbXkgdGFuayBsaWQgbG9ja3MgZG93biBhbmQgaXMgb25seS BhY2Nlc3NpYmxlIHdoZW4gdGhl
IHN3aXRjaCBpcyBwdWxsZWQgZnJvbSBpbnNpZGUgdGhlIGNhci 4gRG8gSSBoYXZlIHRvIGRpc2Fi
bGUgdGhpcyBhbmQgbWFrZSBpdCBzcHJpbmctbG9hZGVkPwoKQ2 FuIHNvbWVvbmUgd2l0aCBleHBl
cmllbmNlIGluIGdvaW5nIHRocm91Z2ggYSBWQSBzdGF0ZSBpbn NwZWN0aW9uIG9mIGEgY29udmVy
dGVkIGVsZWN0cmljIHZlaGljbGUgbGV0IG1lIGtub3cgaG93IG RpZmZpY3VsdCBpdCB3YXM/IEkg
YW0ganVzdCB0cnlpbmcgdG8gbWFrZSBzdXJlIEkgZG9u4oCZdC BkbyB0aGUgY29udmVyc2lvbiBh
bmQgaGF2ZSBhIGNhciB0aGF0IGlzIG5vdCBzdHJlZXQtbGVnYW wuIERvZXMgdGhlIGluc3BlY3Rv
ciBhY3R1YWxseSB3ZWlnaCB0aGUgdmVoaWNsZSB0byBtYWtlIH N1cmUgaXQgaXMgdW5kZXIgdGhl
IEdWV1I/CgpUaGFua3MgZm9yIGFueSBhZHZpY2UuCgotS2VuIE92ZXJ3YX ksIE10LiBTaWRuZXks
IFZBCgpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1 9fX19fX19fX19fX19fXwp8IE1v
cmF0b3JpdW0gb24gZHJhZyByYWNpbmcgZGlzY3Vzc2lvbiBpcy BpbiBlZmZlY3QuCnwgUGxlYXNl
IHRha2UgdGhvc2UgZGlzY3Vzc2lvbnMgZWxzZXdoZXJlLiAgVG hhbmtzLgp8CnwgUkVQTFlJTkc6
IGFkZHJlc3MgeW91ciBtZXNzYWdlIHRvIGV2QGxpc3RzLnNqc3 UuZWR1IG9ubHkuCnwgTXVsdGlw
bGUtYWRkcmVzcyBvciBDQ2VkIG1lc3NhZ2VzIG1heSBiZSByZW plY3RlZC4KfCBVTlNVQlNDUklC
RTogaHR0cDovL3d3dy5ldmRsLm9yZy9oZWxwL2luZGV4Lmh0bW wjdXN1Ygp8IE9USEVSIEhFTFA6
IGh0dHA6Ly9ldmRsLm9yZy9oZWxwLwp8IENPTkZJR1VSRTogaH R0cDovL2xpc3RzLnNqc3UuZWR1
L21haWxtYW4vbGlzdGluZm8vZXYK
Old 07-10-2012, 03:05 PM
Default Re: [EVDL] questions about Virginia HB 780
Ken,
If you cut the fuel tank open (which will be necessary to
use it as trunk) then it can no longer be used as fuel tank
so my impression is that if you show your tank repurposed as
trunk (with lid) and without fuel or fuel line then that should
be acceptable, since it no longer is a fuel tank.
They appear not concerned about the original fuel tank itself
but about people finding a sneaky way to store fuel and just
claim the vehicle to be converted while it is not.
That is why it has "the fuel tank removed and not replaced"
ie it has not a hidden tank in a different place and also the
original fuel tank cannot be used as fuel tank.
Switch in fuel filler door: since that is often the most
convenient place to put your charging plug, it is relatively
simple to add a switch that is operated by the fuel door and
will avoid the high voltage from being connected to the motor.
This also avoids driving away while plugged in so there is
some sense to this law.
My EV has a separate outlet in the grille, but still it has a
little switch in it that will interrupt the 12V drive to the
main contactor coil, so the controller cannot be engaged as
soon as the flap is lifted. The flap is spring-loaded just like
the fuel filler door.
I do not think that you should worry too much about the locking
of the fuel filler cap - any emergency worker can open a wreck
to get a person out so I think he will be able to open a
locked fuel door also when the need arises. The lock is typically
a piece of plastic that is easily broken in emergency.
My impression is that the less you educate your inspector of your
EV, the fewer problems you will experience - especially if you
already put the things in place to satisfy the spirit of the law
even if it may not comply to every letter of the law, such as
the fuel tank removal.
There remains always a risk of course, but if you are creative
then I am sure you will find a way to get your EV registered,
whether by "shopping around" and going to a different DMV location
if one inspector fails your EV, or by implementing the letter if
the inspector insists, just like the guy welding a short piece of
open pipe to the rear of his EV, because in his state it was
required to have a place to stick a smog sensor into.
Success,
Cor van de Water
Chief Scientist
-----Original Message-----
Behalf Of Ken Overway
Sent: Monday, July 09, 2012 1:31 PM
To: xxx@xxx.xxx.edu
Subject: [EVDL] questions about Virginia HB 780
Hi all,
I am about to start my first EV conversion (1997 Miata) and I found
Virginia House Bill 780 which includes some requirements for Converted
Electric Vehicles in order to pass inspection (takes effect in Oct
2012). Does anyone in VA have knowledge of this bill? I'm worried about
passing inspection and want to make sure I cross my t's and dot the i's.
Specifically:
Buried in HB 780 it states
"Such certification shall be on a form approved by the Commissioner and
the Superintendent and shall state that the inspector has verified
that..
(ii) the fuel tank has been removed and not replaced;"
I'd like to convert the tank into a storage trunk since it is located
directly behind the passenger seats. It will no longer function as a
tank and will be cleaned and painted, but it is still the same "tank".
Advice?
Also buried in the code is
"3. An externally mounted switch to open the high voltage circuit in
case of an emergency. Such switch must be located where the fuel tank
filler cap was located prior to conversion. Any cover protecting the
switch must be able to be opened from the outside of the vehicle;"
I wonder if any SPST switch will work. The ignition key already serves
to interrupt the contactor for the battery bank. I was going to just add
another switch in the gas tank flap area that interrupts the 12 V of the
key switch. I think that is what they want. Advice?
Also, like most cars, my tank lid locks down and is only accessible when
the switch is pulled from inside the car. Do I have to disable this and
make it spring-loaded?
Can someone with experience in going through a VA state inspection of a
converted electric vehicle let me know how difficult it was? I am just
trying to make sure I don't do the conversion and have a car that is not
street-legal. Does the inspector actually weigh the vehicle to make sure
it is under the GVWR?
Thanks for any advice.
-Ken Overway, Mt. Sidney, VA
Old 07-11-2012, 07:35 AM
[quote] Ken Overway wrote:
> Hi all,
> I am about to start my first EV conversion (1997 Miata) and I found Virgi=
nia House Bill 780 which includes some requirements for Converted Electric =
Vehicles in order to pass inspection (takes effect in Oct 2012). Does anyon=
e in VA have knowledge of this bill? I'm worried about passing inspection a=
nd want to make sure I cross my t's and dot the i's. =
> Specifically:
> "Such certification shall be on a form approved by the Commissioner and t=
he Superintendent and shall state that the inspector has verified that..
> I=92d like to convert the tank into a storage trunk since it is located d=
irectly behind the passenger seats. It will no longer function as a tank an=
d will be cleaned and painted, but it is still the same =93tank=94. Advice?
Hi Ken,
You WILL be sure to rinse out the tank at least 2 times with detergent and =
water before cutting it open WON'T you? We don't want you to lose your eye=
brows (or anything else more important) when, otherwise, the cutter sparks =
ignite the petrol residue in the tank!
MW
Old 07-11-2012, 08:05 AM
I have used a skill saw and a sawsall to cut open tanks including propane
tanks. Flushing with soap and water is good but I then fill the tank with
water and cut it when it is full. Stay on the top side of the tank and be
sure you are plugged into a GFCI. Use air tools if you have them.
Sincerely,
Mark Grasser
> Hi all,
Electric Vehicles in order to pass inspection (takes effect in Oct 2012).
Does anyone in VA have knowledge of this bill? I'm worried about passing
> Specifically:
the Superintendent and shall state that the inspector has verified that..
directly behind the passenger seats. It will no longer function as a tank
and will be cleaned and painted, but it is still the same "tank". Advice?
Hi Ken,
eyebrows (or anything else more important) when, otherwise, the cutter
sparks ignite the petrol residue in the tank!
MW
Old 07-11-2012, 10:25 AM
Multiple rinses were absolutely on my to do list. I like my eyebrows!
Has anyone ever "re-purposed" a gas tank before?
-Ken
> Hi Ken,
> detergent and water before cutting it open WON'T you?
> We don't want you to lose your eyebrows (or anything else
> more important) when, otherwise, the cutter sparks ignite
> MW
Old 07-11-2012, 11:25 AM
Ken,
In addition to lots of rinsing etc. you also need to keep the air/fuel
mixture in the tank non-flammable when you cut or weld on it. One might
think that the fuel is gone, but there are very small amounts of fuel in
porous or corroded parts of the metal, and along the seams. Some people
use dry ice in the tank which supplies carbon dioxide, non/flammable,
and I have heard of some who route the exhaust from an internal
combustion engine through the tank with the motor on, and then weld or
cut. Be careful, and double check your advice. I have never worked on a
steel gas tank. For cutting I would fill a tank with water and use a
reciprocating saw on it. Welding, be careful, the heat will bring out
any remaining fuel as a vapor and that is bad for risk of explosion or
fire.
Alan
Sent: Wednesday, July 11, 2012 9:22 AM
Subject: Re: [EVDL] questions about Virginia HB 780
-Ken
> Hi Ken,
> We don't want you to lose your eyebrows (or anything else more
> important) when, otherwise, the cutter sparks ignite the petrol
> MW
Old 07-11-2012, 11:55 AM
I let air from a compressor blow into the tank to dry it as well as I could=
, washed it out with soap, filled the tank with argon, and used a nibbler (=
less likely to spark than a cut-off wheel).
To: Electric Vehicle Discussion List <xxx@xxx.xxx.edu> =
Sent: Wednesday, July 11, 2012 11:14 AM
Ken,
fire.
Alan
-Ken
> Hi Ken,
> We don't want you to lose your eyebrows (or anything else more =
> important) when, otherwise, the cutter sparks ignite the petrol =
> MW
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120711/f52cbf1f=
/attachment.html =
Old 07-11-2012, 05:25 PM
Yes, my first attempt at a battery box used the lower half of a fuel tank. I simply washed, dried, sniffed, and cut with a sawzall.
It turned out to be easier and better use of space to build a new box than adapt to the many curves and bumps on the bottom of a Karmann Ghia gas tank...
Here's the final assembly..
http://photos1.blogger.com/blogger/5407/1617/1600/Oct%2015%20photo%20dump%20036.jpg
Jay
www.karmanneclectric.blogspot.com
rom: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On
ubject:
-Ken
> Hi Ken,
MW
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120711/346f7f74/attachment.html
Old 07-12-2012, 01:56 AM
It is a <steel> tank, isn't it? I ask as a lot of modern ones are plastic which would make cutting them a lot safer... Just a thought! MW
[quote] Alan Brinkman wrote:
> Ken,
> fire.
> Alan
> From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On
> -Ken
>> Hi Ken,
>> MW
Old 07-12-2012, 03:25 PM
Hi Ken and all,
In February I had my 98 converted Golf EV licensed and inspected.
Now it is street-legal. I had let the donor vehicle registration
expire during the conversion, and I contacted DMV by phone to learn
what steps to take to register again. (I'm writing this from the top
of my head, and I'll post again shortly with specifics.) The process
involved obtaining a new title and a visit from a state agent to see
the finished work. Once I had the title, then I could drive in to the
inspection station for a regular inspection. I did not not need any
special waiver for the emissions part of the inspection. The Virginia
code made that part simple.
At the time, the registration and inspection loomed large, but that
part was actually much easier than getting a reliable controller
Charlie
[quote] Ken Overway <xxx@xxx.xxx> wrote:
> Hi all,
> Specifically:
> "3. An externally mounted switch to open the high voltage circuit in case=
of an emergency. Such switch must be located where the fuel tank filler ca=
p was located prior to conversion. Any cover protecting the switch must be =
> I wonder if any SPST switch will work. The ignition key already serves to=
interrupt the contactor for the battery bank. I was going to just add anot=
her switch in the gas tank flap area that interrupts the 12 V of the key sw=
> Also, like most cars, my tank lid locks down and is only accessible when =
the switch is pulled from inside the car. Do I have to disable this and mak=
e it spring-loaded?
> Can someone with experience in going through a VA state inspection of a c=
onverted electric vehicle let me know how difficult it was? I am just tryin=
g to make sure I don=92t do the conversion and have a car that is not stree=
t-legal. Does the inspector actually weigh the vehicle to make sure it is u=
nder the GVWR?
