Old 05-16-2012, 12:34 PM
frodus's Avatar
frodus frodus is offline
Default Re: Formula Hybrid
Controller and motor aren't the problem, the battery is. A 125KW battery won't come cheap and at 72V, it's got to have some really badass batteries in there to supply over 1700A (more because the batteries sag).
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and parts Sales
Brammo Empulse R #24
Old 05-16-2012, 12:35 PM
kishor5466's Avatar
kishor5466 kishor5466 is offline
kishor5466 is an unknown quantity at this point
I'm really sorry if i'm making you feel that you're doing homework for me ............. But though i may be knowing the things , it will be taken as a verification when you also suggest the same thing and they will be pretty much practical as you've worked on these kinds of stuff................The calculations even a small kid can do but we shouldn't be facing the practical problems later ........... If we face later then that time i can't come and ask in the forum. so i'm clearing everything out including very small stupid thing.......
Old 05-16-2012, 12:37 PM
frodus's Avatar
What motors, controllers and batteries have you researched?
Travis Gintz
Old 05-16-2012, 12:44 PM
kishor5466's Avatar
The motor will be Yasa 750 with curtis 1238 controller and a LiFePO4 pack
Old 05-16-2012, 12:54 PM
frodus's Avatar
The curtis controller is an Induction Motor controller with no support for BLDC motors. The Yasa 750 is a BLDC motor.
The 1238 series controllers are limited to 130VDC and 650A, but at 650A you'll have sag, so still, only expect about 80kw peak.
What lifepo4 pack? what batteries?
Travis Gintz
Old 05-16-2012, 01:02 PM
kishor5466's Avatar
LiFePO4 is the short form of lithium Iron Phosphate battery pack......... It is a lithium polymer battery pack used in some of the EVs.......
Old 05-16-2012, 01:04 PM
frodus's Avatar
I know very well what lifepo4 means.....
I'm asking about WHAT BRAND and MODEL of cells have you looked at. Not all are created equal. There's 100's of manufacturers of lifepo4.
Travis Gintz
Old 05-16-2012, 01:08 PM
kishor5466's Avatar
Okay Presmatic cells or pouch cells may be............... hey are pouch cells available for such a voltage requirement though they have higher energy density???
Old 05-16-2012, 01:20 PM
frodus's Avatar
You still haven't answered.
What brands of cells have you looked at? Who makes them?
I'm not doing the work for you, come on, try harder. You said you'd compare what we tell you, against what you have done. I'm asking, what have you done?
Travis Gintz
Old 05-16-2012, 03:34 PM
ruckus ruckus is offline
Ok, I am thinking he needs a place to start. Most people start here:
www.evalbum.com
You can see lots of examples and can search by battery brand, type, controller, etc. When you find cars that are similar in performance to what you want, take note of the components used, research their cost and capabilities.
Then you will know a little something.
There are many paths to what you seek. Do you merely want to meet the target? Or do you want to build something cool? You mention 72v pack. I think you must have forgot a zero and meant 720v, yes?
In America we call this humor..
www.northvalleyev.com
