Old 08-06-2012, 07:45 PM
powerhouse powerhouse is offline
powerhouse is on a distinguished road
Default General Range Formula
Hey Guys
I'm working on a small school project and I need some help.
Basically, im creating a very simple range calculator in Matlab, a program maker.
I want to collect some small variables from the user,
Drag Coefficient
Frontal Area
Weight after conversion
Drive efficiency
Tire circumference
Rolling Resistance
battery pack kWh
I need to know how far someone can expect to go at 10, 20, 30, 40 mph etc.
I can't find a formula that incorporates drag and frontal area into finding range. I have tried reverse engineering existing calculators, but jeez they have so many variables its ridiculous.
Also, if any more variables are necessary, or certain ones arent let me know! I just have to figure out how speed is related to range.
Ultimately, I want the program to create a graph showing range vs speed. So the most important part is that I find out how speed is related to range.
Any help is appreciated!
Check For Updates on the S2000!
http://electrichonda.blogspot.com/
Old 08-06-2012, 07:55 PM
Default Re: General Range Formula
You calculate the power required for specific speeds.
The amount of time traveled at a specific speed gives you distance.
The time traveled using a specific power gives you energy.
So using the speed, power, time and energy, you can calculate the distance energy relationship.
Old 08-06-2012, 08:15 PM
Thanks major !!
I haven't taken physics yet so its all kinda new to me.
How do you calculate the power necessary at speeds? I think that would require the drag coeff and Rolling Resistance, but the problem is I don't know the formula that uses those!
Old 08-06-2012, 08:19 PM
TigerNut TigerNut is offline
Force times distance is work done (in the physics sense), this is equivalent to energy.
Force times velocity is power.
You'll have to work out, for each speed you're interested in, what all of the opposing force components are: air drag, tire Rolling Resistance, and gravity (if you're going up hills).
Air drag is proportional to the square of your speed, so you'll find that this starts to become significant pretty quickly. Rolling Resistance goes down slightly with speed, IIRC.
You can search out the appropriate conversion constants on Wikipedia, and there are tables of drag coefficients and frontal areas on ecomodder and elsewhere.
Old 08-06-2012, 08:30 PM
Looking for some formulas, kinda tough
EDIT: I have found a somewhat useful formula
F= (mass x gravity constant x coeff of Rolling Resistance) + ((density of air x coeff of drag x frontal area x (velocity of vehicle)^2) / 2) + (mass x acceleration)
This is for flat surfaces
Old 08-06-2012, 08:40 PM
It is not unique to EVs. It should be many basic vehicle performance books or papers or lecture notes. I took a look and was surprised it wasn't in this site's wiki.
Old 08-06-2012, 08:51 PM
Yeah, I searched diy before I even made the thread. Nothing much on the topic unfortunately.
Using the formula I posted above for force, how would you find power?
Old 08-06-2012, 08:52 PM
F= (mass x gravity constant x coeff of rolling resistance) + ((density of air x coeff of drag x frontal area x (velocity of vehicle)^2) / 2) + (mass x acceleration)
That should give a pretty good first approximation. Most likely it will give at least a 95% accurate answer, and some of the error will be due to errors in the vehicle mass, drag coefficient, or frontal area.
Old 08-06-2012, 09:08 PM
______________________________
Old 08-07-2012, 02:51 AM
PStechPaul's Avatar
Exclamation Re: General Range Formula
I just made a web page using JavaScript that calculates force and power from the equations above. However I probably don't have the units correct, so please check it out and let me know what typical values are and the units so it will be correct. I can also add other common EV calculations, such as the Torque-HP-RPM formula and wheel RPM to speed. I can jazz it up with English/Metric conversions as well.
http://www.enginuitysystems.com/ForceCalculator.htm
I also put a link in the Wiki.
