Old 04-11-2009, 12:37 PM
Dave Koller's Avatar
Dave Koller Dave Koller is offline
Dave Koller is on a distinguished road
Default Getting rid of PCM in Saturn
GO to last pages for new STUFF!!
I edited this opening as it contains other things at the end than about the PCM... hope it is helpful!
Tachometer at the end added 11/22/09 ------------
I have been working on getting rid of the PCM in a 1999 Saturn Sl2. Bypassed the Tachometer on atzi's 1998 Saturn... http://www.saturn.offical.net/node/326
So now it is on to the speedometer. I used a Heathkit (yep, I have one!) function generator
to send a pure sine Wave to the PCM... I settled on 60 MPH as this is the most important one to use - as it represents 1 mile per min or according to the output in all the manuals I could find the Speedometer = 5000 pulses per mile (thus per min) .. What is strange is all the information I can find says Saturn VSS has 10000 pulses per mile (ppm) so at 60 mph I should have 10000 = 1 min and 10000/60 = 166.66666 HZ... right?
But I get 230 HZ for 60 mph !! that equates to 13800 ppm (VSS sine Wave NOT square Wave to speedometer) . SO if that is true then there is a strange number to divide by to get the square Waves for the speedometer ! 13800 / 5000 = 2.76 .. not the best number to digitally divide by !!
So it does a bit of strange processing NOT the simple divide by 2 that 10000ppm would get me !
The formula I use to get MPH from the sine Wave is ---[ MPH x 13800 / 60 /60 = HZ] or 60 x 13800 = 828000 /60 = 13800 /60 = 230 Hz..
Easier to see a different one:
30 (MPH) x 13800 (PPM) = 414000 /60 (min) = 6900 /60 (sec) = 115 HZ (or cycles per sec)
AND YES 115 hz gives me 30 mph!!
I thought I would throw this out to see what others think! Perhaps they phase lock it at some frequency but not sure!
Dave
Old 04-13-2009, 08:07 PM
david85's Avatar
david85 david85 is offline
Default Re: Getting rid of PCM in Saturn
Great work! I'd like to toss the PCM in mine too, but I really want to be able to keep the OEM tach and speedometer.
Old 04-13-2009, 08:50 PM
I have found out much more and will post more pics with scope shots crazy way the PCM figures from VSS - thought it might be a straight algorithm - can't tell if it uses a PLL or just filters with division......
Dave
Old 04-13-2009, 11:29 PM
Used a safety pin into D6 connector Pumped 230 hz sine Wave in to the VSS input...
Got 60 MPH MPH OUT AND 84.32 HZ out of PCM!!
SCOPE:
230 HZ SINE (bottom) in .............. 84.32 perfect SQUARE Wave OUT(top) !!!!!!!! 5000 (ppm that manual says) /84.32 = 59.29 MPH
(close enough)
Figure the meter is off a few HZ and it comes to 5000ppm / 60 sec = 83.33333 my original math for factory!!!
So what the heck is 230 HZ in ? 230 / 84.32 = 2.7277039 aprox ....
Two things still wrong here - the ratio of 2.7 and how the heck are they getting the division ? well I need more work there... Have discovered a pure sine is clean but under noise of EV motor it introduces more pulses -- this opens up a whole new area of RF Noise besides our radios
Dave
Old 04-13-2009, 11:35 PM
PS I ran 28 miles sitting still on the odometer !! lol
Dave
Old 04-14-2009, 12:09 AM
david85's Avatar
The VSS puts out a different frequency than the PCM? Why the heck would they do that? Seems to me like it only complicates things.
Old 04-14-2009, 08:34 AM
The PCM will compensate for various gear ratios, tire size, maybe models, but why I am getting what I am does not relate to what is in certain manuals.. I have run across 10000 ppm for GM and Saturn FROM VSS - that would be nice as it is 2 to 1 (5000 ppm) - easy to convert the sine to pulse at one half frequency with single flip-flop........
http://ecomodder.com/wiki/index.php/MPGuino
scroll down to chart on various cars......
If anyone has more info on VSS from Saturn - jump in here
Dave
Old 04-16-2009, 12:38 AM
Well quick thought... using a PLL like a 4046 locked to 4 X 230 HZ (sine for 60 MPH) out of VSS then divided by 11 (non fraction - my 2.7x X 4) gives 83.xxxx square Wave that divided into the 5000 ppm will give me 60 MPH - well close enough!! I will make that and post some info.....
So since my Saturn only needs the PCM for Speedometer and Tach it looks like a couple of chips can do the job... Now on to interfaceing the temp gauge with pulse width modulation from a thermistor input .... Still no ideas out there?
Dave
Old 04-20-2009, 11:41 AM
Well a PLL of 230 X 100 then divided by 276 will yield the 83.33333 for the 60 MPH on the speedo.... going to make it in components as a pic or Ardunio processor will not output the exact numbers I need... It will be more accurate than the PCM as it will also have a filter system for extreme noise! Both my speedometer and tach will run seperate from all the other things I want to do! I intend to use ALL the idiot lights (of course I will replace them with LEDS! ) out of my own processor and all the temperature sensors, inputs, I can make do other things... OK so we shall see!!!! Be it warped - I still have a sense of humor ...
Dave
Old 04-20-2009, 07:22 PM
david85's Avatar
I'm sorry we don't have anyone else here that can contribute much to your thread, but I am following it. Please keep up the good work.
I actually toyed with the idea of putting "idiot lights" at the front of the dash panel where it sweeps upward. The idea being to copy the look of the EV1.
