Old 03-15-2012, 10:49 AM
PThompson509 PThompson509 is offline
PThompson509 is on a distinguished road
Default Re: Grant electric mini.
Hi Folks,
A friend of mine has a Kewet (possibly smaller than your mini), and she replaced the old worn-out DC motor with an AC motor from HPEVS. The motor is the AC50, and can be ordered from the factory with a transaxle. She was able to fit it in using Geo Metro drive shafts, with no machining needed.
Cheers,
Peter
Old 03-15-2012, 01:32 PM
Studebaker Studebaker is offline
Studebaker is on a distinguished road
That would be something for me. How can one order it? All pages on their website say “ This Page is Under Development
Check Back Soon “
Can’t even find the e mail address.
Old 03-15-2012, 05:05 PM
Well, not quite all. Not sure what the deal is. However, they do have phone numbers (how 20th century!) on their website tho.
I'll see if I can locate an email address for you. Another possibility is for an EV vendor near you to order it...not sure who would be best for Ireland.
Cheers,
Peter
Check Back Soon “
Old 03-15-2012, 08:52 PM
Jaesin Jaesin is offline
Jaesin is on a distinguished road
I'd go for the Think! drivetrain. I am using a chain drive and a simple DC setup because of cost and simplicity but expect it to be noisy.
Old 03-15-2012, 10:55 PM
Duncan Duncan is offline
Yes, but then you would have to turn the diff around. I think they deigned to spin in certain direction. You know the annoying whizz that comes from diff when you reversing. You’d have it all the time in the set up where diff is spinning in opposite direction.
I think you would turn it around and upside down - then all of the gear loads would be in the right direction
Old 03-16-2012, 06:08 AM
You right mate. I guess starring at computer screen all day long makes me see the world in only two dimensions.
Old 03-16-2012, 07:10 AM
MalcolmB's Avatar
MalcolmB MalcolmB is offline
I was just reading through Caspar's build thread and noticed there's a slight problem with the Think system. Top speed for the Think was limited by the controller to 90 kph, but with 10" Mini wheels that drops to 70 kph.
Caspar, if you're following this, did you manage to find out how to increase the controller's rpm limit?
Mini conversion:
Old 03-16-2012, 08:11 AM
Originally Posted by PThompson509 View Post
Hi Folks,
Cheers,
Peter
Is this a single speed transaxle? What ratio?
Old 03-16-2012, 08:33 AM
MalcolmB's Avatar
It sounds like the Azure Dynamics system. Fixed ratio of 10:1.
http://www.azuredynamics.com/product...oductSheet.pdf
Mini conversion:
Old 03-16-2012, 04:20 PM
electricmini's Avatar
electricmini electricmini is offline
electricmini is on a distinguished road
Actually this mini is an automatic. But, how to hook the motor to a gearbox where the gearbox is actually a sump? Seen it done thou. Metal plate bolted to the top. Then motor to it, chained up with a layshaft. Can’t say I liked it.
I still have the setup from my Mini pickup conversion - which was based on an automatic Mini gearbox. We (Paul Compton and me) removed all the insides, leaving just the diff & final drive pinion. Paul then made a shaft and adaptor to bring the shaft out of the side where the transfer gears used to be, put the motor on top and coupled it up with a big toothed belt.
Worked ok, could do with having bearings on both sides of the belt
The gearbox is still here outside my garage, even the motor is still here & looking for a new home! Fancy a trip to Cardiff?
Would be nice to see another electric Mini, especially if it's got lithium cells....
Richard
