Old 06-14-2012, 09:15 AM
Jaesin Jaesin is online now
Jaesin is on a distinguished road
Default Re: Grant electric mini.
I think a 7 inch deep box would let me keep a new boot floor level that is even with boot opening. I don't know if there is some sort of pre-determined safe clearance for chassis parts. A skid plate might be a good idea.
I want to keep as much space as possible in the boot as I use it quite a bit.
It is very easy to get stuff in and out since it opens like a tail gate.
- Jaesin
Old 06-14-2012, 02:44 PM
Studebaker Studebaker is offline
Studebaker is on a distinguished road
There’s 9 inches between the levels of boot and cabin floor, so 7 inch deep box will still sit higher than the main floor. You could actually go full 9 inches with no trouble I guess.
Old 06-20-2012, 01:35 PM
HPEVS HPEVS is offline
HPEVS is on a distinguished road
Figured I would jump in here. The motor for the Graziano transaxle is different from the one you have. The AC50 you need is the one for a Wheego, it is designed to bolt directly to the Graziano.
Brian Seymour
HPEVS
http://www.HPEVS.com
Old 06-21-2012, 04:58 AM
Thanks mate. You wouldn’t have more information , would you? I mean …say, how to get one of those?
Old 06-21-2012, 11:58 AM
We can build you one. Very few of the parts in the standard AC50 work with the Graziano style motor. My suggestion would be to find someone to buy the motor you have and buy the correct motor for the trans, or use an adapter to use the motor you have on a standard trans.
Brian Seymour
HPEVS
Old 06-23-2012, 05:25 AM
“We can build you one” …is, what kind of money we talk about?
Old 06-23-2012, 06:38 AM
You are in the $1800 range. You may want to just look at buying a kit with controller, it's a little cheaper that way, unless you have a controller already. Keep in mind, if we didn't provide the controller setup for that motor, the software in the controller most likely won't have the motor characterization for the AC50 in it.
Brian Seymour
HPEVS
Old 06-27-2012, 04:37 AM
Originally Posted by HPEVS View Post
You are in the $1800 range..
Sounds reasonable.
Old 06-27-2012, 09:46 AM
Originally Posted by Studebaker View Post
Sounds reasonable.
We also have the Graziano transmissions in an 8.5:1 ratio in stock.
Brian Seymour
HPEVS
Old 07-11-2012, 10:01 AM
Right. I’ll be on the market for one of those, mate. Give me few months, thou. Need to bring this mini back- to something that resemble car - first.
