[quote] Tom <xxx@xxx.xxx> wrote:
> On some models the high side of the switch is feed through a different
> source of power and not through the resistor block that feeds the lower
> fan speeds. It might be dropping out because of that?
My VW is also wired like this. When the fan is on HI, the switch actually
activates a relay that connects the blower motor directly to the 12V
system.
I used 4 diodes (1N4001?) to tap power directly from my fan speed switch,
but I did have to make a small wiring change for the HI setting. After the
diodes I have 3 switches that are activated by the temperature slider. As
you slide from "neutral" to "hot", the switches activate 1/2, 1, or 2 PTC
heater elements.
I know temperature output depends on airflow, but I don't like high flow
rates most of the time. And I don't like getting cooked when I need just a
little heat to keep the windshield defrosted
-Adrian
