Originally Posted by monkmonkey
See that fuse? Never use steel hardware (nuts, washers, etc) in the high current path. That is a certain failure point. Clamp the lugs directly to the fuse tabs. And what is with drilling Anderson lugs to use for battery terminal connectors? Bad, very bad idea. You're lucky it didn't run.
Sorry to be blunt, but your wiring really needs help.
