Old 10-15-2009, 02:14 PM
280z1975 280z1975 is offline
280z1975 is on a distinguished road
Send a message via AIM to 280z1975 Send a message via MSN to 280z1975 Send a message via Skype™ to 280z1975
Default Help with range calcualtion ...
Well i am in the mist of planning to build an E-scooter. I am looking at using some LIFEPO4 batteries and want to know what kind of range I can expect.
The batteries are 48V - 20AH ones from Ebay. Some of the auctions say to expect 60 to 80km range, but is this realistic in real life?
I am looking to use the moped to do pacing training with cyclists (it's quieter and no fumes for the cyclists) to do at least one hour of pacing at 45km/ph. I know to sustain this speed for a regular cyclists is in the 300 to 450 watt range, but for a scooter?
The battery has .960 KWH of capacity and I would like to be able to go 1.5 hours of at the 45kph. Is this realistic?
Thanks for the help.
Old 10-15-2009, 02:53 PM
Tesseract's Avatar
Tesseract is on a distinguished road
Default Re: Help with range calcualtion ...
Seems it's harder to come by good energy requirements for scooters and motorcycles, but I keep coming across the figure of 75Wh/mile. If that is at least nominally correct then you'd need a little over 2kWh of battery capacity.
Jeffrey Jenkins
http://www.evnetics.com/
Old 10-15-2009, 02:58 PM
Thanks for the suggestion on Wh/m ... I know the basic wh/m for cars, but like you, for motorcycles and mopeds, not as much data.
Now if I can only convince my wife a Solition1 is a needed controller for the scooter ... it will make for some fun (and short) training sessions for the riders.
Old 10-15-2009, 03:09 PM
samborambo's Avatar
NZEVA Member
Based on...
Cd = 0.7
Frontal Area = 0.6 m2
Weight = 180kg
Crr = 0.003
Pack = 960Wh
Range of 67km to 100%DOD at 45km/h. That's ideal conditions. No stop-and-go.
Power required at 45km/h is 550W.
Old 10-17-2009, 05:47 AM
mxmtech mxmtech is offline
mxmtech is on a distinguished road
I'm using 5 amps to go 20 kmh 15 amps to go 30 kmh without a headwind or a hill. I'm only using a 24 volt 12 AH SLA battery pack though. My pack is dead in an hour at 20 kmh and dead in 15 min at 30. A scooter just has to be heavier than a conventional bicycle configuration. A scooter will be darned hard to pedal home when the batteries die, better to call a tow truck.
My motor is 450 watts
Old 10-17-2009, 10:04 AM
boyaka boyaka is offline
boyaka is on a distinguished road
pick a speed
or go full throttle and find out what your watt consumtion is and speed
then firgue out how many watts hours your battery pack is then divide battery pack watt hours by you consumtion then multiply by speed and that how many miles you will be able to go on that pack
this is a rought estimation
Old 10-17-2009, 10:15 AM
Originally Posted by boyaka View Post
pick a speed
That might be possible IF I had an electric scooter, which I don't. I do, however, have my racing bicycle which does have a watt measuring device, www.srm.com, from which I know it takes about 400 to 450 watts to sustain that speed (total bike and rider weight was less than 80kg, 23mm tires and a flat road). But I don't know what the difference would be for a scooter and rider (around 150kg) with larger tires and larger frontal area.
The best place to estimate the watt requirements I can find/know is this one:
http://www.analyticcycling.com/
-Gregg-
