Old 06-26-2012, 05:57 PM
JRP3's Avatar
JRP3 JRP3 is offline
Default Re: Hpevs ac50
From CALB themselves, charge cutoff at 3.6V
http://www.calibpower.com/ProductDetails.aspx?p=2&id=3
Those of us who have been using the cells for a while can attest to the fact that there is almost no extra capacity going above 3.5V.
Old 06-27-2012, 09:44 AM
HPEVS HPEVS is offline
HPEVS is on a distinguished road
Originally Posted by tomofreno View Post
I use the minibms so cells shunt at 3.5V. Within 20 minutes the pack relaxes to less than 124V, and within a couple hours they are less than 123V. Just driving 2/10 mile and stopping they are down around 120V. I drive down about 1/2 mile long hill after that and if I keep regen currents 25 to 50A the pack V remains below 123V. Always amazes me I can run that much current into them right after full charge and less than 2Ah used and they don't go higher in voltage.
Were the high voltage warnings you've had due to regen currents? If so, do you know their magnitude? I'm using the regen limiting map to limit max regen to about 140A. That is about what I get if I remove my foot from the accelerator when traveling at 50+ mph for a quick stop - don't want to over-volt my cells if I have to emergency stop not long after full charge. Also have the user_overvoltage parameter set to 130% or 124.8V. I have exceeded it a couple times, regen cuts out, and the car accelerates down the hill.
Yes, 3.6 is the max voltage CALB recommends.
How things have changed. Early days of Thundersky Li Fe cells the recommended voltage was 4.25 V. We never went over 3.8. Over the next month or so, I'm going to collect some real world data and see the capacity difference between 3.5 vpc and 3.7 vpc. I know when charging the cells stay in the 3.4 to 3.5 vpc area for a long time. If they are actually fully charged at 3.5, then the amount of energy to recharge will drop significantly than going all the way to 3.7.
Answer to your question Tom: It has occasional over voltage trips right after charging when in regen. Who knows, we may find we can go 48 cells without issue, stay tuned.
Brian
Brian Seymour
HPEVS
http://www.HPEVS.com
Old 06-27-2012, 10:10 AM
Ivansgarage's Avatar
Ivansgarage Ivansgarage is offline
Ivansgarage is on a distinguished road
Hi Brian
Could you tell me what would be the max voltage (batts)
I can use on a 1238-6501 controller. Will be using lif batts
Thanks Ivan oh fix your tag line link for hpev
Ivan's Garage 1999 Electric Sonoma Pickup
http://ivanbennett.com/forum
This is just a test! Hand wound motors.
Old 06-27-2012, 10:18 AM
Originally Posted by Ivansgarage View Post
Hi Brian
Hi Ivan,
The 6501 is rated at 84 volts nominal, I have pushed it to 96 (30 cells) with lithium. The max voltage is 105 volts.
We are looking in to the link now, can't figure out why it is being routed through DIY. I have sent DIY an email, haven't heard back yet.
Thanks,
Brian
Brian Seymour
HPEVS
Old 06-27-2012, 11:06 AM
frodus's Avatar
frodus frodus is offline
edit your sig in "User CP" above, go to "Edit signature", highlight the "www.hpevs.com" and click on the "break link" icon, then click on the "link" Icon and retype the URL.
Hope that helps
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and parts Sales
Brammo Empulse R #24
Old 06-27-2012, 11:13 AM
Hope that helps
Thanks Travis, I think that worked. If you don't mind, please test it on your end to make sure.
Brian Seymour
HPEVS
Old 06-27-2012, 11:17 AM
Hope 48 looks ok. The CALB spec has always been different than Thundersky. It was 3.6V three years ago when JRP3 and I bought our cells from them when they were called SkyEnergy.
The charge curve below was taken on one cell when charging the pack at 25A. Charging current started tapering off toward the end of charge, but lets be generous and say it remained at 25A the entire time. Then between 3.450 and 3.701V the cell received 25*(3100-2652)/3600 = 3.1 Ah. Probably more like 2.5 Ah considering the current dropping off.
Attachment 13359
Wow, that is way different than the Voltronix (Thundersky) I have in the Porsche. I'm updating the BMS this week with new software. I'm going to set it up at 3.5 volts max and see if the over voltage trip goes away.
Thanks for the info,
Brian
Brian Seymour
HPEVS
Old 06-27-2012, 11:26 AM
frodus's Avatar
Yup, works fine!
Travis Gintz
Old 06-27-2012, 11:39 AM
JRP3's Avatar
That was actually too high really, and I think the reason a lot of people killed some cells prematurely. I think it resulted from poor translations of Chinese instructions which probably said not to go over 4.25V, which people took to mean charge to 4.25V.
Old 06-27-2012, 11:45 AM
Brian
I deleted the post on this charge curve because there seems to be an error in the time axis when imported from LogView into Excel. The values seemed to be about what I had seen in other tests so I didn't catch it right away. I'll see if I can figure it out...
Edit: collected new data and reported it here: http://www.diyelectriccar.com/forums...1&postcount=62
