Hybrid Highlander Conversion - DIY Electric Car Forums
Old 04-04-2008, 01:22 AM
HIDriver HIDriver is offline
HIDriver is on a distinguished road
Default Hybrid Highlander Conversion
What would it take to convert a hybrid highlander to full EV (i.e. remove the ICE and reuse the electric motors and transmission...add batteries and controller)?
Thought the electric motors were larger than the one in the RAV4EV to drive the generator to charge the batteries.
Cost prohibitive?
Old 04-06-2008, 04:02 PM
Mastiff's Avatar
Mastiff Mastiff is offline
Mastiff is on a distinguished road
Default Re: Hybrid Highlander Conversion
I'm assuming you mean this vehicle:
http://en.wikipedia.org/wiki/Toyota_Highlander
It, like all other Hybrids probably uses an undersized electric motor and controller.
This means you'd either have to add a second motor and controller system.
Or replace the motor/controller inside the Highlander for higher power ones that can handle highway driving.
The batteries included in the Highlander are probably not usable because you'd have to either completely disassemble the battery pack or rebuild it into a bigger battery pack or toss it and build a new pack.
The batteries are also most likely NiMH cells.
It would probably be more costly to do this than to start with a cheap used ICE version and convert that in an ideal way.
We ran out of places to put the Perpetual Motion advocates, because Australia was already taken.
Old 04-06-2008, 05:03 PM
RAV4 EV motor is a 50kw.
The 4wd Hybrid Highlander has two motors...a 123kw (in front) and a 50kw (in rear).
I don't think the motors are undersized...just the 123kw motor is doing more work by turning a generator to charge the on-board batteries and starting the ICE.
The max speed under EV mode is around 30mph.
Is that the software governing the speed?
What if we install another motor controller, more batteries (such as LiFePo4) and eventually removing the ICE...would this work?
Old 04-06-2008, 10:51 PM
vrod vrod is offline
vrod is on a distinguished road
Anything is possible but converting any SUV will be expensive because of the weight and aerodynamics.Larger and more expensive components will have to be utilized.
