Yes! I have long searched for it and now I finally found the solution!
I want to use my iPad or iPhone to monitor my Elithion Lithiumate BMS so I don't need to use my laptop while (test) driving.
I now have successfully tested the latest version of the Get Console apps for both iPhone and iPad.
In order to make this work you need:
- obviously a Lithiumate BMS
- obviously an iPad or iPhone
- the latest
Get Console app from the Apple App Store
- the special
Redpark C2-RJ45 cable for iPhone/iPad
- a
RJ45-to-serial DB9M adapter (DB9 male or DE9 male)
It works!
No more laptop needed, just use iPhone or iPad to monitor your Lithiumate system! :-)
Also the on-screen iPhone/iPad touch keyboard can be used to control your Lithiumate!
And it gets even better: you have the ability to do remote access from any location via the Internet by settting up a web sharing session !
No jailbreaking needed!
See the screen shots in this post.
Settings:
19200 Baud
Flow control Xon Xoff
Parity None
Stop bit 1
Bits 8
//Martijn
