Old 06-09-2012, 05:20 PM
Whitehawk Whitehawk is offline
Whitehawk is on a distinguished road
Default Kelly KDC36100 shorted? Stays full throttle...
I just wired up my electric bike, it worked during the first power up sequence, then it is broken. Using KDC36100. For testing, I have a 35amp fuse installed on main circuit. Also, I'm using this 40amp relay, says it has a Diode so I didn't put one in the circuit.
Mystery throttle switch, I put a rocker switch in...not sure what that switch is for, manual says "(5)Micro_SW (white): Close to GND to activate. Default as throttle switch", switching it to pin 10 (Ground) does nothing. Actually, for the first startup, when the throttle worked, I left that circuit open.
I turn on the main power switch and the controller is stuck on full throttle, with the LED off. Also, the 1k 10w pre-charge resistor gets very warm to the touch.
I am using this throttle from kelly
I programmed the controller for 0-5k pot (only other options are "hall throttle" and "3-wire"). I also current limited to 28% and set the voltage limiting range to 21v-28v. I tested the throttle output voltage (throttle wired red, black, white...so I put the 5v on the red and the white is signal), at 0% throttle I get 0.8v and at full I get 4.2v.
It still runs even if I unplug the throttle signal wire.
Is my controller blown?
I DID NOT SHORT ANYTHING OUT, or wire stuff backwards.
Old 06-09-2012, 08:01 PM
RIPPERTON's Avatar
RIPPERTON RIPPERTON is offline
RIPPERTON is on a distinguished road
Default Re: Kelly KDC36100 shorted? Stays full throttle...
A Kelly throttle is a Hall throttle
says in the web page
dont need throttle switch
My YouTube Channel http://www.youtube.com/user/RIPPERTON?feature=mhee#p/u
Old 06-10-2012, 07:28 AM
Ya, apparently if you set it up with a the "5k pot" for the throttle and use a Hall Throttle, the controller fails.
Old 06-10-2012, 10:17 AM
If you need something done, then you have to do it yourself...
50 amp rated hall current sensor using arduino:
http://arduino.cc/forum/index.php/topic,109400.0.html
and the Arduino Nano also controlling the H-bridge (IC Driver IR2110) using some big n-mosfets and current limited feedback (with the above current sensing system). Radio Shack should have another breadboard in stock =/ I already have all the parts in stock, but because I need this much earlier to display, I just purchased an off-the-shelf POS, until further notice we'll see what Kelly says...lol
Old 06-11-2012, 09:45 AM
Measured 0 ohms between M and B- terminal with the unit detached and not installed...that is probably not good.
Old 06-11-2012, 08:26 PM
RIPPERTON's Avatar
Tell Kelly what happened even if its out of warranty
they might be able to fix it or show you how to reflash it
Old 06-12-2012, 10:12 AM
Yup, they are working with me via email, now asked for serial #. Time zone issue kinda sucks, 1-question / 1-answer per night =(
Old 06-12-2012, 08:24 PM
RIPPERTON's Avatar
Fany is very helpful
hes a guy btw.
1 "n" male
2 "n"'s female
