Old 01-19-2011, 08:59 AM
Plamenator's Avatar
Plamenator Plamenator is offline
Plamenator is on a distinguished road
Send a message via ICQ to Plamenator
Default Re: Kostov 9" 220V HV motor?
They are not on the site indeed.
We are starting the first batch for customers and stock in 10 days.
Until then I have some final tweaking to do so I expect proper drawing+performance curves to be uploaded in 2-3 weeks time.
A good battery for it will be something like 70x90Ah lithium cells to give 224V/~210kg/~8500$/20kWh.
BTW, we should also have the new Soliton Junior in stock within a month.
If you have any suggestions/questions about this motor, I will be glad to hear them
Old 02-09-2011, 11:39 AM
GerhardRP GerhardRP is offline
GerhardRP is on a distinguished road
The drawing is up twice, one following the pointer to the drawing, the other reached by following the performance curves link .
Gerhard
Old 06-30-2012, 08:33 AM
kishor5466's Avatar
kishor5466 kishor5466 is offline
kishor5466 is an unknown quantity at this point
Originally Posted by Bowser330 View Post
With the Soliton-1 controller 220KW(295HP) is possible for as long as the motor can hold 1000A at speed, however with 220V i imagine the 295HP would only be available up to 3500rpm or so...
RoughRider may have been referencing my post above stating "295hp"
220V*1000A = 220kw = 295hp ~ 300hp
this really confuses me ,........
the power that the motor can supply is it not the nominal voltage of the battery*motor current??? or as it is calculated above as battery voltage* controller current???
if second one is the case then can't we use a high current rated controller with a low power rating (comparatively) to get high output power??
Old 06-30-2012, 04:27 PM
Battery voltage sags under load.
Also examine battery discharge rates.
Your last sentence doesn't make sense. "lower power rating" to get "high output power"
Old 08-15-2012, 06:00 PM
Power in = Power out (minus losses) << This site has taught me that
So when I said 220V and 1000A i meant both at the motor. So 220V is your sagged pack voltage...meaning you motor will never be voltage(rpm) limited.
275V battery pack sagged 20% = 220V, so even when drawing 1000A, your pack voltage can be 220V.
